Broken Carb.
https://slantsix.org/forum/viewtopic.php?t=12593
Author:  NewSlanter [ Mon Apr 11, 2005 8:30 pm ]
Post subject:  Broken Carb.
Just re-did my manifold gaskets (No broken bolts or studs- Thank goodness), but when it came time to re-install the carb, I managed to over-torque the mounting nuts and cracked the base-plate(D'oh!). My question is this; is it possible to have the carb welded (it's a Holley 1920 in pretty good shape- other than being in two pieces!)? Or am I insane for even thinking of it? I'd buy a re-build, but I know this one works (worked) and financial constraints make it a bit dicey. Help Please!
Author:  bbbmmm [ Mon Apr 11, 2005 8:41 pm ]
I don't think you'll have much luck with a repair. My advice would be to get a used carb to salvage parts from.
Author:  Avenger2040 [ Mon Apr 11, 2005 8:52 pm ]
Post subject:  Hoo man.........
Better get a new carb, I really don´t think it can be welded, even repared.
Author:  NewSlanter [ Mon Apr 11, 2005 9:52 pm ]
That's just as I feared. While I'm at it, I was thinking of replacing the automatic choke with a manual set-up. Any advice?
Author:  Dennis Weaver [ Tue Apr 12, 2005 6:37 am ]
Get a good plastic sleeved cable at NAPA.
D/W
