| Kickdown https://slantsix.org/forum/viewtopic.php?t=12597 |
| Author: | Jimluw [ Tue Apr 12, 2005 7:40 am ] |
| Post subject: | Kickdown |
I am converting to the Super Six setup. I have the kickdown assembly mounted on the manifolds, but it seems like the other end doesn't quite fit in the bracket on the transmission. Should I modify it to fit, or do I need a different bracket? |
| Author: | SlantSixDan [ Fri Apr 15, 2005 10:44 am ] |
You need the entire linkage, including all the levers, brackets and springs up at the manifold, the correct shorter throttle cable, the correct kickdown rod that runs down to the transmission, and the shorter kickdown lever on the transmission itself. |
| Author: | 70valiant [ Fri Apr 15, 2005 2:47 pm ] |
what are you super sixing? |
| Author: | Jimluw [ Mon Apr 18, 2005 9:01 am ] |
Thanks. Sounds like I have everthing but the small lever on the transmission. I am Super Sixing my '71 Dart Swinger. |
