Hi, I need a torqueflite A-904 handbook
https://slantsix.org/forum/viewtopic.php?t=12598
Page 1 of 1
Author:  SL6 CHILE [ Tue Apr 12, 2005 8:04 am ]
Post subject:  Hi, I need a torqueflite A-904 handbook
Author:  Eric W [ Tue Apr 12, 2005 10:31 am ]
Hi. Find a Factory Shop Manual for your year of car. There are sites on the web that sell them. Whats your problem? Many people here can help.
Author:  Guest [ Thu Apr 14, 2005 10:24 am ]
[quote="Eric W"]Hi. Find a Factory Shop Manual for your year of car. There are sites on the web that sell them. Whats your problem? Many people here can help.[/quote
Thank you. Im not sure of the position of the balls on valve body]
Author:  relic-lover [ Thu Apr 14, 2005 7:33 pm ]
Post subject:  figure 5
This figure should help.
http://members.cox.net/relic-lover/valve904.JPG
Author:  Eric W [ Thu Apr 14, 2005 10:51 pm ]
Told you..... :wink: 8)
Author:  Guest [ Fri Apr 15, 2005 9:44 am ]
Thank you very much!!!
And I have a new question:
When I step into the accelerator smoothly the shifts are too long and to make them go fast I must step into the accelerator like a quarter or so, this way the shifts go faster. But, this makes me have no kick down. If I step the accelerator to the floor I don’t have kick down. ¿What could be causing this?
¿Could this be the torque converter?
¿Could this be the valve body?
Thanks!
Author:  Rust collector [ Fri Apr 15, 2005 10:11 am ]
Maybe adjust the kickdown linkage?
Or if you had the valvebody in pieces, maybe the pressure regulator was adjusted wrong?
Author:  Guest [ Fri Apr 15, 2005 10:31 am ]
How I can regulate the governador pressure???
Author:  relic-lover [ Fri Apr 15, 2005 2:51 pm ]
Post subject:  727 and 904 manual
Automatic Transmission Manual for Chrysler/Jeep 727/904
JC Whitney Part Number - ZX167287Y
Author:  SL6 CHILE [ Fri Apr 15, 2005 2:58 pm ]
Thank you very much relic-lover !!!
Author:  Seis Inclinado [ Sun May 08, 2005 10:02 pm ]
Try this link
http://www.allpar.com/mopar/torqueflite.html
Enjoy
Author:  Guest [ Mon May 09, 2005 8:02 am ]
Gracias Rafa
Author:  argentina-slantsixer [ Mon May 09, 2005 5:09 pm ]
try to adjust the kickdown linkage and see if it's moving along with the throttle lever. This may be cause 1. Cause 2 may be the valvlebody assembled wrong (but this would cause a lot more trobubles that you'd notice) Also take a look underneath the car , check if kickdown lever that goes to the kickdown shaft is tight and moving free or the lever is moving but the shaft ain't. above the kickdown-shifter levers is the main pressure adjustment screw, it has a counterlocking nut, try to turn it 2 or 3 turns clockwise and see what happens.
Author:  Guest [ Wed May 11, 2005 11:05 am ]
Thanks
