| 70valiant' i have a question https://slantsix.org/forum/viewtopic.php?t=12622 |
| Author: | bencrabtree [ Thu Apr 14, 2005 7:59 am ] |
| Post subject: | 70valiant' i have a question |
in your picture of the hei setup their is a wire on your coil nmot in the wireing diagrams. you have 2 ewires on the negative terminal of the coil, one goes to the hei module, what does the other one go to? the instrutions given for this setup only show a wire from the coil negative to the hei module. |
| Author: | Rust collector [ Thu Apr 14, 2005 8:25 am ] |
Tach? |
| Author: | NewLancerMan [ Thu Apr 14, 2005 8:55 am ] |
It looks aftermarket, so i think rust is right. I know mine also has a little radio static supressor on the coil. IF you don't have another wire, don't worry. Just get the HEI wire right. MJ |
| Author: | 70valiant [ Thu Apr 14, 2005 2:25 pm ] |
yep, it goes to my mini sun tach. |
