It is currently Tue Jun 09, 2026 5:45 am
PostPosted: Thu Apr 14, 2005 7:59 am
in your picture of the hei setup their is a wire on your coil nmot in the wireing diagrams. you have 2 ewires on the negative terminal of the coil, one goes to the hei module, what does the other one go to?
the instrutions given for this setup only show a wire from the coil negative to the hei module.
PostPosted: Thu Apr 14, 2005 8:25 am
Tach?
PostPosted: Thu Apr 14, 2005 8:55 am
Car Model: 1962 Lancer 770
It looks aftermarket, so i think rust is right. I know mine also has a little radio static supressor on the coil. IF you don't have another wire, don't worry. Just get the HEI wire right.
MJ
PostPosted: Thu Apr 14, 2005 2:25 pm
yep, it goes to my mini sun tach.
