| Please, tell me it's not too late!! https://slantsix.org/forum/viewtopic.php?t=12664 |
| Author: | '74 Sport [ Mon Apr 18, 2005 7:16 am ] |
| Post subject: | Please, tell me it's not too late!! |
Aaron and I are just about ready to test fire his slant six and see if all systems are GO. Then it dawned on me, when we went to Wallyworld to buy all the various and sundry fluids. We took a list of all the fluid capacities from the Haynes manual. Let's see... transmission - 8 qts. Dexron II or Mercon. Wait a sec., does that include the torque convertor? Holy moly - how do you fill an empty torque convertor - after it is already installed? Please, tell me we don't have to pull the transmission to do this. Jerry |
| Author: | slantzilla [ Mon Apr 18, 2005 7:20 am ] |
Just pull the coil wire and turn the motor over with the trans in Neutral for awhile. The pump will fill the converter. |
| Author: | Rob Simmons [ Mon Apr 18, 2005 8:06 am ] |
See? It's not too late! Let us know how the break in goes. Very exciting! |
| Author: | Pierre [ Mon Apr 18, 2005 11:53 am ] |
Its not absolutely necessary to fill the converter before installing it, just a precaution so you don't run it dry on inital start. I'd do like slantzilla said in your case. If you want to get creative, you can take out the drain plug out and turn the converter so the plug isn't straight down (maybe remove the starter and gain access to the drain plug hole from up top?), then use one of those hand pump attachments on a quart of atf and pump some in the drain hole that way. Or find a funnel with a skinny tube, that may work as well. |
| Author: | '74 Sport [ Mon Apr 18, 2005 3:24 pm ] |
Well, all of you certainly eased my mind with your comments. I was about ready to flip my wig. Of course the topic of this post reveals my ignorance of the inner workings of a transmission. I had hoped the fluid would equalize itself in the torque convertor by filling the tranny, but something in the back of my mind nagged at me about pre-oiling it. I did not know it is an open system, with them sharing fluid. I like the idea about pulling the coil wire and turning over the engine a few times. Actually, Pierre, you read my mind. I even thought about removing the TC drain plug and squirting some oil into it that way, just so it won't be bone dry. Seems like every time we go to do something, it's always two steps forward and one step back... take this off to do that; move that over to do this; can't find this; wrong size that......I'm sure you know the old story. Yesterday, we were going to install a mechanical oil pressure gauge to monitor the new engine break-in. Couldn't find a single wrench that would fit the oil sending unit. 1" was too small, 1-1/16" was too large, Cresent wrench just slipped off the round shoulders. Hated to do it, but the ol' Vise Grips did the job. I know we didn't use them two years ago when we first installed it. We were also going to install the new radiator hoses. The "correct" upper hose was about 3" too long, and to force it on put a deep kink in the hose. Three stores later, we got the right one at Advance Auto. If it's not chicken, it's feathers. Thanks again for the words of relief, Jerry |
| Author: | Jeb [ Mon Apr 18, 2005 5:52 pm ] |
A special sending unit socket is required to remove the oil sending unit. Had to use visegrips and lots of profanity to get mine off. Ever had the oil light come on going down the freeway at 80 MPH. Like to have had a heart attack when it happened to me. Fortunately it was a bad sending unit. |
| Author: | Craig [ Mon Apr 18, 2005 5:55 pm ] |
Just start the engine and let it run in NEUTRAL and the torque converter will fill itself. |
| Author: | Rob Simmons [ Tue Apr 19, 2005 5:01 am ] |
Hey Jerry, All that two steppin' will be well worth it when you and Aaron get it all done and start takin' it cruisin'. |
| Author: | '74 Sport [ Tue Apr 19, 2005 11:44 pm ] |
Rob, Believe me, Aaron inspires me every chance he gets. What's frustrating for me is that we are really getting close to testing out all our work, but our busy schedules keep putting it off. Aaron's youth activities at church, or his Saturday track meets, or my school board obligations, or this, or that.... Then throw in the set-backs from wrong parts and such, it really gets irritating. But you're right, it wasn't that long ago that we had the whole back end of the Dart cut off. Now that is inspiring. Thanks for the boost, Jerry |
