It is currently Wed Nov 18, 2026 2:13 am
PostPosted: Sat Apr 23, 2005 7:28 pm
Summit did an excellent job getting the cable to me.... Awesome service! The instructions included from Lokar are dismal at best. I think the bracket that connects to the tailshaft is pretty straightforward, but at the carb end I'm not "getting it" :?
From the tailshaft, the cable turns 180 degrees & goes up to the engine compartment. Is the cable supposed to then do another 180 from in front of the carb position to come back to the linkage? Do I need to fabricate a bracket for the carb end?
Any info is greatly appreciated, and if anybody had a pic or two, I'd be very grateful!
If a bracket is needed, I'm thinking about fabricating an integrated bracket/EGR cover/spring return plate out of aluminum to handle all the cables & bracketry.... I've already done an EGR cover/spring return & polished it.... Looks great, but I want the Lokar setup & Super Six stuff to be a real clean install....
Thanks!
Oldsarge
1964 Dart 170, Some work done, lots more to come!
PostPosted: Sat Apr 23, 2005 10:13 pm
I installed one on a 361 (throttle pull direction should be the same). you will just come in from the back of the carb, no need for another 180. Here's a couple pics, let me know if you need any more info.
I used the bracket from lokar. it makes it really easy to use both their throttle and kickdown cables.
PostPosted: Sat Apr 23, 2005 10:41 pm
Ahhhhhh! Things begin to make sense! Thanks for posting the pics... I'm going to fabricate a bracket for the throttle & KD Cables, and will also be an EGR cover, and arm for the return spring..... Hopefully I can make it a one-piece deal that will make for a nice clean install. Will post pics if I'm successful!
Thanks again!
Oldsarge
PostPosted: Sun Apr 24, 2005 3:34 pm
Sounds good, looking forward to the pics.
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
