Def and Heat controls.
https://slantsix.org/forum/viewtopic.php?t=12763
Page 1 of 1
Author:  Avenger2040 [ Mon Apr 25, 2005 12:59 pm ]
Post subject:  Def and Heat controls.
Anyone got a diagram of how to wire cables to controls? My temp control is loose and my Off- Heat - Def control just don´t work, is a 71 Duster.
Author:  Avenger2040 [ Tue Apr 26, 2005 3:06 pm ]
Ok I ve found by my own way how the system works, but looks like 2 of my 3 cables aren´t working, meaby broken by inside, someone got some of them for spair or know where I can buy them? (A place that ships to Mexico)
Author:  64 Convert [ Tue Apr 26, 2005 5:49 pm ]
There are usually 2 things that make cable inoperative. If the outer shield gets a sharp bend, they stick, but the most common thing is the cables get rusty inside the shield.
Disconnect your cables from the heater and see if they operate while not attached, to eliminate the doors as your problem. If they operate stiffly, or not at all, remove the controls from the dash, carefully straighten any bends and lubricate with a rust buster oil.
Author:  Avenger2040 [ Tue Apr 26, 2005 7:58 pm ]
Ok, then I remove my cables and check operativity, if they got none even with lubrication, there is a problem, also they don´t seem to hard to make new ones.
