Little knocking in the engine.
https://slantsix.org/forum/viewtopic.php?t=12776
Author:  weezzle [ Tue Apr 26, 2005 6:17 am ]
Post subject:  Little knocking in the engine.
My old 86 dodge 150PU has a slight knocking at a certian RPM. I know it is the risk pin or main knocking. But really how long can you drive like this? When you hear it knock you can give it a little throttle and it seems to go away until you get back at a certain RPM. I guess it has something to do with pressure build up?
This is not an everyday driver but just an old pickup to have around when needed. i know I need to replace the manifolds and I have already put a new carb on it. It actually runs pretty good exept for the knocking.
Author:  Jukka-80Aspen [ Tue Apr 26, 2005 12:08 pm ]
If I was you, I would first try to change higher viscosity engine oil, for example 15W-50, in case you don't have tried it already. I have found that it prevents some noices in worn-out engines. Maybe that will help you till you rapair it.
Jukka
