77 super six with 833 OD into 64 Dart wagon with 904
https://slantsix.org/forum/viewtopic.php?t=12798
Author:  bbbbbb9 [ Thu Apr 28, 2005 2:16 pm ]
Post subject:  77 super six with 833 OD into 64 Dart wagon with 904
What issues do I need to look out for?
This engine runs great and tranny also.
I am going to rebuild both and am looking for a daily driver with some pep.
I will probably go Dutra Duals, port and polish the head and little else.
Will the 64 K member accept the 77?
Can I use the tranny mount from the Aspen?
DO I need a totally new hump?
Z bar issues?
I also have a 8 & 1/4 rear out of a 74 Duster that I got the parts from for the disc brake swap.
Thanks in advance
Author:  killin5 [ Thu Apr 28, 2005 2:23 pm ]
Post subject:  Pan
You need 66 or earlier pan to work with the 64 K member.
John
Author:  kesteb [ Sun May 01, 2005 10:32 am ]
The F-body oil pn can be used if you dimple the left front corner of the sump and use a V8 center link. If that is not available, then you can dimple the pan where it rests on the center link.
