| gas direct in carb only way to start https://slantsix.org/forum/viewtopic.php?t=12802 |
| Author: | exoJjL [ Thu Apr 28, 2005 5:25 pm ] |
| Post subject: | gas direct in carb only way to start |
after taking my carb off the other day, and the fuel inlet needle coming out and putting it back in, now it wont start unless a pour a bit of gas in the carb. Theres a part on my carb i forget what ts called, i just push it down and it puts some gas in the carb. thats the only way i can get it to start real fast, then once i do, it wont start started if i hit the gas (i have to hit it real slowly, and its hard backing upwards out of my driveway, damn hill) |
| Author: | 64 Convert [ Thu Apr 28, 2005 6:30 pm ] |
Did you replace the needle valve correctly? It's easy to reverse it. |
| Author: | Doctor Dodge [ Thu Apr 28, 2005 9:12 pm ] |
May-be a vacuum leak. What is the fuel pressure? DD |
| Author: | exoJjL [ Thu Apr 28, 2005 9:43 pm ] |
Im pretty sure I replaced it correctly. My carbis the 1920. I put the point of the needle pointing outwards from the carb. Im not sure what my fuel pressure is. How can I check it?? |
| Author: | mbjones99 [ Fri Apr 29, 2005 5:06 am ] |
you put the needle in backwards. |
| Author: | exoJjL [ Sat Apr 30, 2005 4:48 pm ] |
damn! I checked the choke last night and it was still open in idle so the needle being backwards makes sense now! |
| Author: | exoJjL [ Sat Apr 30, 2005 4:50 pm ] |
what the hell!! i did put the point of the needle into the carb........ |
| Author: | exoJjL [ Sat Apr 30, 2005 11:29 pm ] |
ok, this is &#@% confusing, if i put it in backwards, in another thread theyre saying thats not backwards! And I cant find a photo of all the pieces on the carb broken down.....if anyone has any pictures or know a place.... |
