| Headers. Help Please!! https://slantsix.org/forum/viewtopic.php?t=12808 |
| Author: | rawduster [ Fri Apr 29, 2005 3:32 pm ] |
| Post subject: | Headers. Help Please!! |
ok guys i know this has been ask befor, but are there any other headers out there beside "Dual Dutra Duals" or hookerheaders. I had the hookerheaders but they didnt have the thick flang to match the offenhouser intake. I had to make some spacer and they just dont work that well. O and if you have to know Its a 70 duster with a 225 /6 bor 30 over and the head is shaved 60 thousands and lift on the cam is 440 I think. So any help with better headers would be great. Thanks guys. |
| Author: | sixty4dartgt [ Fri Apr 29, 2005 5:20 pm ] |
I have the Offy intake and I use Clifford performance headers. The flange size is not a problem. |
| Author: | SlantSixDan [ Fri Apr 29, 2005 6:19 pm ] |
"Better Headers" = Dutra Duals. |
| Author: | 70valiant [ Fri Apr 29, 2005 7:25 pm ] |
I use Cliffords with a super six intake, works great. |
| Author: | rawduster [ Fri Apr 29, 2005 9:19 pm ] |
how long did it take you guys to get your clifford headers? I keep seeing were it takes them forever to send them to you when you order from them. Is this true? Or is ther another place I can get them? Thank guys for the fast help. |
| Author: | 70valiant [ Sat Apr 30, 2005 4:20 am ] |
I picked mine up used at the swap meet at Carlisle. |
| Author: | Charrlie_S [ Sat Apr 30, 2005 4:45 am ] |
What I do, when I order from Clifford. I ask if the part is in stock. If it is I ask for a delivery date. Then I give them my credit card number, and tell them, if I do not have the item, by that date I will cancel the order, and put the CC amount in dispute. Do not listen to their excuses. If the item is not in stock, do not order. Tell them you will call back, when the item is in stock. This has worked for me. |
| Author: | rawduster [ Sat Apr 30, 2005 9:51 am ] |
thank. Ill give them a call and see what I can come up with. |
