| 69 Dart 4 Speed Conversion Questions https://slantsix.org/forum/viewtopic.php?t=12815 |
| Author: | imnoisydart [ Sat Apr 30, 2005 5:50 pm ] |
| Post subject: | 69 Dart 4 Speed Conversion Questions |
Considering a 4 Speed Conversion on a 69 Dart 225 (currently 904). I did a 340 4 speed conversion a couple of yrs. ago on a Dart, so I know alot of what is involved (4 spd hump, pedals etc.) I know I need a SL6 bellhousing and trans. Questions? Is the Sl 6 Z bar different from the V8's? Since a factory 4 spd SL6 was never offered in 67-9, would a SL 6 3 speed Z bar work (if I could even find one)? Can the Z bar be eliminated if a hydraulic clutch system is used, and does anyone have an idea of a common hydraulic setup to use? |
| Author: | Dartvader [ Sun May 01, 2005 7:05 pm ] |
The slant six Z bar from a three speed will work. The v-8 will not. You will need a slant specific bell housing for a 4 speed. They came on Volares and Aspens from the mid to late 80's. I think I have a slant 4 speed bell housing if you get stuck and can't find one. If I can dig it up $50 plus S&H will get it to you. |
