| What is best carb (2bbl) for slant six????? https://slantsix.org/forum/viewtopic.php?t=12820 |
| Author: | ramchargerbs [ Sun May 01, 2005 4:31 am ] |
| Post subject: | What is best carb (2bbl) for slant six????? |
I put a slant six in my 78 Ramcharger...I put the two barrell intake also...I'd like to find a good dependable...mid CFM carb...holley or Carter to mount. Would anyone have any suggestions? I took out a 400BB...passed everything cept the gas station. I am pleased with the /6..but need help/advice for good carburation. Thanks all.............. |
| Author: | argentina-slantsixer [ Sun May 01, 2005 6:44 am ] |
holley 2300? offy intake with 2 1920's ? I can't decide between those setups for myself, so go figure if I can pick one for you... the only "drawback" about the dual 1 barrels is that they have to be tuned very good. And if you don't like to tweak your carbs, go carter. Any holley is nice god knows I love them, but they HAVE to be tweaked almost permanently (once a month)... (or this may be a thing that holley freaks do just for giggles?) Carter carbs you put them together you bolt'em to the manifold and then next tune up would be when your throttle shaft is leaking. (6 months? hehehe) |
| Author: | Johnny Z [ Sun May 01, 2005 5:44 pm ] |
Carter BBD..............End of discussion. |
| Author: | Jeb [ Sun May 01, 2005 6:13 pm ] |
Yep, absolutely posulutely correct. |
