| 68 air cleaner on a 73 https://slantsix.org/forum/viewtopic.php?t=12825 |
| Author: | moparDuster [ Sun May 01, 2005 11:36 pm ] |
| Post subject: | 68 air cleaner on a 73 |
can i take a 68 air cleaner on a 73. and would there be a diffenance in power? |
| Author: | Dennis Weaver [ Mon May 02, 2005 6:39 am ] |
Yes. No. (well, you'll probably get a .0001% increase in hp.) D/W |
| Author: | SlantSixDan [ Mon May 02, 2005 7:29 am ] |
You'll have to plug off the air cleaner vacuum line on the '73 carb, and your cold-weather driveability may suffer some, depending on what kind of climate you live in. And no, there wouldn't be a difference (improvement) in power. |
| Author: | moparDuster [ Mon May 02, 2005 3:42 pm ] |
i live in California so i't mostly warm at here year round. another thing i was wondering about was on a 60's ir cleaner not sure what year for to be exact. On the bottom plate it had a vaccum line running form the exuhaust manifold to the air cleaner. so any one know the deal with that. I didnt get that one was just wondering about it. I love them juck yard. just like a truasure hunt you never know what you can dig up. |
| Author: | SlantSixDan [ Mon May 02, 2005 7:32 pm ] |
That would be a '69, with the one-year-only* carburetor anti-ice system. It channels air from the clean side of the air filter, via a rubber hose, through a steel tube that passes through the #2 runner of the exhaust manifold, to a fitting at the base of the carb. This feeds heated air to the underside of the throttle plate to prevent ice-up. It's largely unneeded with today's fuel formulations and tends to make hot-weather problems (carb boiling). The '70 introduction of the thermostatic air cleaner was a much, much better solution.* - This system was available in Canada from '61-'69, but was only used in the US in '69. |
| Author: | Jeb [ Tue May 03, 2005 5:57 am ] |
Flip your air cleaner lid upside down. |
| Author: | SlantSixDan [ Tue May 03, 2005 3:36 pm ] |
Quote: Flip your air cleaner lid upside down.
All that does is make more noise.
| Author: | Dennis Weaver [ Tue May 03, 2005 3:40 pm ] |
Quote: Quote: Flip your air cleaner lid upside down.
All that does is make more noise.D/W |
| Author: | SlantSixDan [ Tue May 03, 2005 4:23 pm ] |
Quote: Quote: Quote: Flip your air cleaner lid upside down.
All that does is make more noise. |
| Author: | Dennis Weaver [ Tue May 03, 2005 4:36 pm ] |
I like running a taller than stock element for Baaahgability. Looks more pro-feshunile than a flipped lid! D/W (8:1)400 + 750AVS + 2.76:1 = BWAAAAAAAAAAAAAAAAAAAAAAAH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
| Author: | moparDuster [ Wed May 04, 2005 11:07 am ] |
how about one of those little single barrel air filters? you know the really small one like two inch. i put one on just for fun and well i'll i could here was air being sucking in. you know know some like SSSSSSSSSSSSS |
| Author: | Jeb [ Wed May 04, 2005 2:11 pm ] |
Those tiny little open element air filters clog up very quickly, due to their small size. Open element filters are not a very wise choice either. You'e best bet is to rig up some sort of cold air intake system. Hey Dennis, that big Newp has 2.76 gears and what is BWAAAAAAAAAAAAAAAAAAAAH!!!!!!!!!!!!!!!!!!!!!!!!!! |
| Author: | 440_Magnum [ Wed May 04, 2005 3:44 pm ] |
The sound of the secondaries opening up when you floor a big-block with a Thermoquad! Dennis said AVS, but compared to a TQ an AVS is "bwaaaaaaaaaaaaaaaaaahhhh!!!! " at best! |
| Author: | Dennis Weaver [ Wed May 04, 2005 3:53 pm ] |
Quote: Dennis said AVS, but compared to a TQ an AVS is "bwaaaaaaaaaaaaaaaaaahhhh!!!! " at best!
...I gets by. D/W |
