Lokar Cable Kickdown Question
https://slantsix.org/forum/viewtopic.php?t=12873
Page 1 of 1
Author:  Daddiojoe [ Thu May 05, 2005 10:07 am ]
Post subject:  Lokar Cable Kickdown Question
Sometimes I just don't get it, but I'm hoping somebody can explain. :oops:
I've got a 71 D100 with a 727 transmission. Because I can get a really good deal and I've had a lot of problems with BBD throttle shafts, I'm thinking about picking up an Edelbrock 500cfm 4bbl.
Lokar has a kickdown cable for 727 transmissions. On my transmission, the kickdown is activated by a kickdown rod.
So, how does a cable take the place of a rod? Is there some extra lever to install or something?
Thanks for your learned responses,
Joe
Author:  slantzilla [ Thu May 05, 2005 12:21 pm ]
The cable takes the place of the rod, and has a bracket that mounts at the tailshaft extension. On the kits that I have, I had to make a small bracket for the carb end, but it wasn't complicated and worked very well when done. :shock:
Author:  argentina-slantsixer [ Thu May 05, 2005 4:17 pm ]
hey.
I did a custom bracket on the carb lever too.
later I drilled 2 holes above the one you see, so I can get 3 kickdown feels, a short throw one for firmer shifts and moer sensitive kickdown, a middle position and a "town" mild shifting that feels like the stock rod.
Author:  Daddiojoe [ Fri May 06, 2005 6:12 am ]
Thanks, 'zilla and Slantsixer.
How does the bracket hook up to the transmission? Do you have the kit number? All I could see was the cable itself.
Thanks again for your expertise,
Joe
Author:  Pierre [ Fri May 06, 2005 1:32 pm ]
I have the 904 kit in my car... I thought the 727 and 904 are same cables?
On my 904 kit, the transmission bracket is built into the cable itself, its just a small tab of metal that the cable already goes through, and you bolt into one of the tailhousing bolts. The cable comes from the carb to the tailshaft bolt, pulls a 180, then attaches to the kickdown.
Author:  argentina-slantsixer [ Fri May 06, 2005 2:26 pm ]
727 and 904 are indeed the same cable. code is H....xxx...2727 or something like that :wink:
