It is currently Sat Nov 21, 2026 11:58 am
PostPosted: Mon May 09, 2005 9:59 am
Hello All,
I need a source for the fuel inlet fitting on a Holley 1920 carb. Other numbers on the carb are
3398 1S 0151
3419582
Also I could use the piece of Fuel line that has the correct fitting to screw into the fuel inlet
Thanks, Dave
1965 Dodge Dart GT
PostPosted: Mon May 09, 2005 10:14 am
New fuel inlet fitting comes with a carburetor rebuild kit. Steel line with correct fitting is just plain old 5/16" diameter steel brake line tubing, available in lengths from "short" to "long" at any auto parts store, but rather than mess with hardline between the fuel pump and the carb, look at This instead.
