It is currently Sat Nov 21, 2026 3:04 pm
PostPosted: Tue May 10, 2005 1:20 pm
Hi :roll:
Any one know where I can get dist. cap hold down clips for a 74 electronic ign. dist.?
Thanks
\6T
PostPosted: Tue May 10, 2005 2:03 pm
They're all the same on the Chrysler aluminum-housing slant-6 distributor, whether it be a points-type or electronic unit. (think even V8s use the same clips). Grab 'em off a wrecking yard car.
PostPosted: Tue May 10, 2005 3:22 pm
Dan, got any ideas where I can get some for a Delco Remy distributor? The clip seems to be the same on many, most, or all DR distributors in the 1950's and 1960's.
PostPosted: Tue May 10, 2005 3:24 pm
Argh. I'm afraid the only response that comes to mind is the smartass one ("...off a Delco-Remy distributor from the '50s and '60s..."), which you don't need. I'd check in Hemmings in the "Services Offered" section; there are some ads, I think, for specialists in distributor restoration. I'm betting they have lots of them.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 5 guests
