| spring clips (distributor) https://slantsix.org/forum/viewtopic.php?t=12925 |
| Author: | \6T [ Tue May 10, 2005 1:20 pm ] |
| Post subject: | spring clips (distributor) |
Hi Any one know where I can get dist. cap hold down clips for a 74 electronic ign. dist.? Thanks \6T |
| Author: | SlantSixDan [ Tue May 10, 2005 2:03 pm ] |
They're all the same on the Chrysler aluminum-housing slant-6 distributor, whether it be a points-type or electronic unit. (think even V8s use the same clips). Grab 'em off a wrecking yard car. |
| Author: | Craig [ Tue May 10, 2005 3:22 pm ] |
Dan, got any ideas where I can get some for a Delco Remy distributor? The clip seems to be the same on many, most, or all DR distributors in the 1950's and 1960's. |
| Author: | SlantSixDan [ Tue May 10, 2005 3:24 pm ] |
Quote: Dan, got any ideas where I can get some for a Delco Remy distributor? The clip seems to be the same on many, most, or all DR distributors in the 1950's and 1960's.
Argh. I'm afraid the only response that comes to mind is the smartass one ("...off a Delco-Remy distributor from the '50s and '60s..."), which you don't need. I'd check in Hemmings in the "Services Offered" section; there are some ads, I think, for specialists in distributor restoration. I'm betting they have lots of them.
