swapping 170 to 225
https://slantsix.org/forum/viewtopic.php?t=12962
Page 1 of 1
Author:  VDART [ Thu May 12, 2005 9:27 pm ]
Post subject:  swapping 170 to 225
Hello, looking to purchase a 1965 225 3 speed manual tranny, does the crank shaft have any special bushings that need removal before installing? It's going in a 62 904 push button car. Everything else should bolt , it's coming from an A body so the oil pan is ok. Thanks !!!
Author:  Doctor Dodge [ Fri May 13, 2005 6:45 am ]
Everything should swap right over. (as long as the 65 engine has never been "messed with")
On a 170 to a 225 swap, the exhaust header pipe will move up appx 1 inch and may bang on the cars floor, add a spacer right at the flange as an e-z fix. You will need a new fan belt for the 225 (longer)
Getting the taller 225 under the 62s heater box is tough so be sure to remove the plastic/fiber cover to make life easy.
Author:  relic-lover [ Fri May 13, 2005 11:27 am ]
Post subject:  watch the hood clearance
Some of the early air cleaners on the 170s hit the hood if used with
a 225 - Just check the hood clearance before slamming the hood the
first time. If you use the 65 air cleaner it should be fine.
Author:  Rust collector [ Fri May 13, 2005 11:46 am ]
Ship the 170 to me, and you will be fine!
Author:  VDART [ Fri May 13, 2005 4:28 pm ]
Post subject:  swap
Guys thanks for the info, fairly sure it's an original & the guy is more than willing to help on shipping/crating. Hey Rust-C do you want the 170 a piece at a time or the whole boat load!! I probably won't install until necessary- but it's always better to have the parts needed before the job begins. Later
PS--- the engine is coming from the land of none other than Mike Jeffries(sp), Nebraska, maybe that's good karma. For those of you who don't race he is the Buzzin half dozen racer that defies logic in his super fast slant powered valiant!! My son & I got to check his ride out last Topeka Mopar show (October 2004) & are looking forward to this year's event
Author:  Rust collector [ Fri May 13, 2005 4:50 pm ]
Dennis Weaver is going to rebuild a newport, so we can use it as the boat it is, so send it to him, and he will do the rest.
Author:  HyperValiant [ Fri May 13, 2005 9:02 pm ]
Im seriously interested inthe 170 block,rods and crank.
HyperValiant
Author:  NewLancerMan [ Fri May 13, 2005 9:10 pm ]
How interested? Contact me. I have a cherry 170 block that will only be here until mid June. 34k grandma miles on it (not joking). I'd love to work something out so I don't have to haul it to California. I was going to ebay it once I swapping the 225 out, but if you're willing to come out here to Ohio (its about 7 hours from DC, maybe a little less) we can do something.
lemme know. I do need the oil pan (or a replacment 225 pan and pickup)
MJ
Author:  SlantSixDan [ Fri May 13, 2005 9:18 pm ]
Doug's wife will love you for getting yet one more oil pan and pickup out of the garage/yard when you get to California.
Author:  NewLancerMan [ Fri May 13, 2005 9:19 pm ]
true that...doug you need some wifey points? I KNOW I DO! Finding a happy home for this 170 would certainly get me in good shape there ;-)
