135 2.2 turbo pistons question
https://slantsix.org/forum/viewtopic.php?t=12971
Author:  Slant6Rat [ Fri May 13, 2005 6:00 pm ]
Post subject:  135 2.2 turbo pistons question
Whats the difference between the 84-85 2.2 turbo piston and the later 86-90 piston? They both seem to have a 1.573" compression height. Are the pin hole heights or pin sizes different? Would either work in a 225 long rod /6?
Author:  Doctor Dodge [ Sat May 14, 2005 9:17 am ]
On the Silvolite pistons I have used, piston material, piston dish size and pressed vs a floating piston pin were the differences.
The turbo piston is the better unit but the bigger dish yields lower compression and should be set-up as a floating pin. More info and photos in the Stroking article.
Author:  Slant6Rat [ Sat May 14, 2005 11:54 am ]
Thanks Doc!
The one's I'm thinking of are the Fed Mogul #532-P dish and the Fed Mogul #533-P circular dish with 2 reliefs. As far as I can tell these are the cast turbo pistons supplied to Chrysler by Mogul.
