Gotha cast rocker arms (Pics)
https://slantsix.org/forum/viewtopic.php?t=12998
Page 1 of 1
Author:  SlantSixDan [ Sun May 15, 2005 11:03 am ]
Post subject:  Gotha cast rocker arms (Pics)
Gotha cast iron rocker arms are mentioned in a lot of the early-'60s Slant-6 buildup articles. A few years ago, I found a set, new old stock in a mouldering box. Snagged 'em, cleaned 'em up, and thought I'd post some pictures.
The box says "1960-62 Valiant Lancer Plymouth Dodge 170 225 6cyl 1.6 ratio Intakes Only". I'm not sure why the admonition not to use them on the exhausts. Perhaps the thinking was that rockers like these would only be used with a camshaft much biggger and compression much higher than stock, and using these 1.6:1 rockers might cause the exhaust valves to smack the pistons...? Seems odd, to me.
I might've installed them on my car the last time I had the top end open, but I noticed that these rockers have only one oil passage, from the shaft bearing rearward to the adjustor/pushrod area. There's no oil feed to the front of the rocker. Seems to me this would tend to starve the rocker tip-to-valve and the valve stem-to-guide junctions, but I'm not sure. I also thought to add the missing passage, but that seems like very delicate work, and I'm not familiar enough with casting intricacies to assess the risk of breaking or otherwise ruining a rocker in the attempt to drill the forward passage.
So, here're the pics:
Image Image Image Image Image Image
Author:  Slant Cecil [ Sun May 15, 2005 2:20 pm ]
Cool!! 8) That would have made a nice street rocker if it had proper oiling. Too bad something like this will never be made again due to tooling costs vs sold units.
Author:  NewLancerMan [ Sun May 15, 2005 3:00 pm ]
hey dan, that garage pic looks awful familiar...but I daresay yours is looking even more crowded ;-)
MJ
Author:  SlantSixDan [ Sun May 15, 2005 8:07 pm ]
I wondered how long it would take you to see my blatant copycat action!
Author:  NewLancerMan [ Mon May 16, 2005 5:06 am ]
ah you know, I've been kinda busy lately....little slow on the up take;-) Cracked me up though! Glad you copped to it, the details are just too good!
MJ
Author:  440_Magnum [ Mon May 16, 2005 10:57 am ]
MJ
Nah, he blew it completely! His car has the reverse lamps in the wrong place, wrong color reverse lamps in the right place... and.....
Its green.
:P
Author:  NewLancerMan [ Mon May 16, 2005 11:25 am ]
hehe i guess there's always a little more devil in the details.... ;-)
MJ
