| need help on 1920 holley carb https://slantsix.org/forum/viewtopic.php?t=13029 |
| Author: | varanger99 [ Wed May 18, 2005 6:00 am ] |
| Post subject: | need help on 1920 holley carb |
i got a 71 ply scamp 225 (/)6 and i put a rebuilt advance auto carb on it. it idles real good but when i go down the road i hit the gas pedal it goes a little and then start sputter like its starving for gas or something.i need helllllllpppppppp |
| Author: | gearhead [ Wed May 18, 2005 9:06 am ] |
More than likely, the main(primary) circuit is not getting fuel...clogged jet, super low float level, air leak somewhere in the circuit which kills the signal that pulls fuel to the venturi...its hard to say from the minimal description given. It could be a number of things... Karl |
| Author: | Eric W [ Wed May 18, 2005 9:37 am ] |
You probably have a puny #50 something jet in the reman. carb. Swap it out for at least a #60 and see if that dosn't help. Make sure the accelorator pump arm is in the middle hole of the linkage (located on the rear of the carb). Also, do as gearhead says and check the float level. |
| Author: | Avenger2040 [ Wed May 18, 2005 7:57 pm ] |
| Post subject: | Talking about Holley 1920 carb |
I just repaired my choke, but tell me if I´m wrong, the choke closes air acces to make engine heats faster in cold days, and opens acces when engine is warm right? If that is right I just assabled wrong my choke. |
| Author: | Slant6Ram [ Thu May 19, 2005 5:46 am ] |
| Post subject: | For best results. |
Quote: choke closes air acces to make engine heats faster in cold days, and opens acces when engine is warm
The choke is not a cold weather feature, it's a cold engine feature.A cold motor, even if it's a hot day, requires a richer fuel mixture to start. After starting, the 'vacuum choke pull off' opens the choke partially to allow airflow, but maintain a rich flow of fuel. The choke is also linkaged to the idle step up cam, so the cold motor will also idle faster to avoid stalling. On a hot day, the thermostatic choke should open within just a few minutes of driving, and allow the idle step up cam to go back to normal. It's taken me a couple of years of fiddling and adjusting to understand and then get everything adjusted. Every time I have adjusted one part, the rest need re-adjusted. It is a constant battle. Now I know why they invented electronic fuel injection. |
| Author: | Avenger2040 [ Thu May 19, 2005 9:05 pm ] |
Ok, ok sorry, bad writting (I was sleppy and almost drunk) but the result is the same, I can´t get my choke working and more since the bolt that keeps resistor in place had broken. |
