| Tie Rod end lengths? https://slantsix.org/forum/viewtopic.php?t=13033 |
| Author: | NewLancerMan [ Thu May 19, 2005 4:51 am ] |
| Post subject: | Tie Rod end lengths? |
Guys, does anyone know if there is a noticeable length difference between the pre and post 73 tie rod ends? I know that they are different (different P/Ns too) but a friend is buying new ones and wants to know *how* different. I guess the price difference is substantial: $40 for the early, $10 for the later model. Just curious MJ |
| Author: | slantvaliant [ Thu May 19, 2005 6:17 am ] |
I couldn't find the real difference, so I punted. I ordered C-body (11/16") tie rod parts. A little more than the '73-'73 parts, less than the early parts. |
| Author: | slantvaliant [ Thu May 19, 2005 6:18 am ] |
http://www.slantsix.org/forum/viewtopic ... highlight= |
| Author: | Charrlie_S [ Sun May 22, 2005 11:51 am ] |
I went to the parts warehouse, on Friday, and compared the different tie rod ends. Moog numbers,ES401R&L, for the 70-76 "A" body. ES319R&L for the 62-90 "A" body, and the ES352R/ES355RL for the "C" body, all have the same tapered stud. The "C" body ends have a 11/16 dia thread into the sleeve. They will all physically fit the steering arms and the drag link, however the ES401L&R have the "shank" at a different angle to the joint body. It is possible by substituting any of the other parts for the ES401L&R, the joint could be put into a bind at the extreams of suspension/steering movement. Lou, did you notice this different angle, and was there any problem with the joint being at the extream end of it's range of it's movement? |
