| Tire Choice https://slantsix.org/forum/viewtopic.php?t=13052 |
| Author: | Slanted Opinion [ Fri May 20, 2005 7:25 am ] |
| Post subject: | Tire Choice |
Hi everyone: Just ordered a PST (rubber) suspension kit for my '68 Dart 270, 4-dr sedan. Also ordered KYB shocks for the front. (Rear suspension rebuild comes later). I know there are a million possibilities, but I'm looking for opinions on tires. The car came with 14x6 mag rims on the front. I need something for regular street use, and I pull a heavy popup camper, so handling stability is important. It currently has a well used set of Cooper P215-60-R14 on the front. Any thoughts? Thanks! -Mac |
| Author: | Johnny Z [ Fri May 20, 2005 9:22 am ] |
To me the size is correct maybe go to a 215-70-14 which is a little taller.(better clearance) But as far as what brand you can go to a site called www.tirerack.com and punch in your size tire and get reviews on tires from customers.I have bought tires from them for a very nice savings,delivered to my door. Hope this helps JZ |
| Author: | SlantSixDan [ Fri May 20, 2005 10:22 am ] |
BFGoodrich Radial T/A P205/70R14. |
| Author: | Dart270 [ Fri May 20, 2005 12:09 pm ] |
Personally, I won't go back to anything taller than 60 series tires. 215/60-14 is an excellent choice for your Dart on those rims. I have run 215/60s and 225/60s on my 68 for years and love them. 70s will give you a smoother ride, but more flex and worse handling. There are always 15, 16, 17" rims/tires too... (keeping lid on worm can) My two cents... Lou |
| Author: | Dart270 [ Fri May 20, 2005 2:45 pm ] |
I was asked by PM about my "worm can" comment. I just meant that there are infinite options for 15+ wheels/tires and I can discuss at length if people have specific questions. I have 16x8s on my 64 Dart, 14x7s on my 68 Dart, 17x8s on my 66 Valiant. All work well to varying degrees. Lou |
| Author: | Guest [ Fri May 20, 2005 3:50 pm ] |
So to make everyone happy. 215/60-14 BFGoodrich Radial T/A |
| Author: | james longhurst [ Fri May 20, 2005 3:54 pm ] |
lou- it's good to see your location has changed!
| Author: | sandy in BC [ Fri May 20, 2005 3:55 pm ] |
I like 235/60r14....with 8" rims. You need the shocks and suspension that will go with them though. I wouldn t do it without a stout swaybar.
| Author: | NewLancerMan [ Fri May 20, 2005 4:03 pm ] |
Quote: So to make everyone happy.
I run the same, work fine
| Author: | NewLancerMan [ Fri May 20, 2005 4:08 pm ] |
James are those SBP? Just curious....clearly more than I can afford, esp with the viper caliper mounted at the back.... MJ |
| Author: | NewLancerMan [ Fri May 20, 2005 4:51 pm ] |
well it looks pretty darn good. Good beverage and damn nice headlights...I think you should send those to me MJ |
