pulling my hair out with timing
https://slantsix.org/forum/viewtopic.php?t=13075
Page 1 of 1
Author:  socalrat [ Sat May 21, 2005 8:27 pm ]
Post subject:  pulling my hair out with timing
If I install the new pertronix unit i can get it to run but the mark is not even on the timing tab. Tried installing it 5 ATDC, 5 BTDC to no avail. Not much adjustability on these distributors compared to my chevelle. I assume the firing order is clockwise. Correct. And what should my idle speed be set at on a 72 variety 225 engine. I have way more time invested trying to get this car running than I would care to admit. I have the firing order as 153624 going clockwise. Is this correct. May checke TDC tomorrow wit a piston stop before I go crazy. Thanks.
Author:  gearhead [ Sat May 21, 2005 9:19 pm ]
Sounds like the gears in a tooth off...is the rotor pointing at number one when the piston is at TDC and the timing set at TDC?
Gearhead
Author:  socalrat [ Sun May 22, 2005 7:01 am ]
I've move the distributor forward a tooth and back a tooth without sucess. THis is a used motor that we never heard running. Wondering if timing chain may have jumped a tooth or is stretched. Will verify TDC this morning
Author:  Bob D [ Sun May 22, 2005 5:51 pm ]
Did you know that there are two adjustments on these distributors? One is accessed from the bottom side of the distributor. Your correct, the firing order is 153624 clockwise.
Bob D
Author:  socalrat [ Mon May 23, 2005 7:41 am ]
Post subject:  Thanks to all
Bob, Searching the forums after posting I found a response refering to the "second" adjustment nut. Cured the problem and it is now purring like a kitten. Thanks again to all who have responded to my MOPAR questions over the past few weeks. :D
Author:  moparfiend [ Tue May 24, 2005 1:48 pm ]
those that want more adjustment on your timing can take the adjuster off a later model distributor. it will give about 110 deg of adjustment.
