It is currently Tue Oct 13, 2026 10:13 pm
 Post subject: recurve problem
PostPosted: Sun May 22, 2005 11:24 am
I have a recurved distributor with 16 degrees mechanical advance.
904 transmission, stock motor with headers and 2 barrel manifold and a Weber.
As I understand it, 30 degrees initial+mechanical is ideal.
A 10.5 or 11 vacuum can is needed to get up to the low 50's for economical cruising.
My research shows that:
Niehoff AL317 = GPSorensen VCC530 = Napa VC3029 = 8.5degrees
Neihoff AL346 = GPSorensen VCC535 = Napa VC3034 = 9.5 degrees
Neihoff AL348 = GPSorensen VCC537 = Napa VC3036 = 8.5 degrees
I've ordered a half dozen of these and they always come up 8.5 or 9.5 !
There must be differences in how much vacuum is needed to initiate the advance.
I really wanted to try an 11 can, but if I use one of these is it OK to recurve the distributor to have an init+mech of 35 or 36 degrees?
OK. I searched here and found that 32 is about the limit.
PostPosted: Sun May 22, 2005 11:25 pm
At the track I find that 28 to 30 degrees total timing make the car faster.
On the street, more advance gets better MPG, as long as you can keep the engine from pinging.
PostPosted: Mon May 23, 2005 7:06 am
Don't worry necessarily about making it to the low 50s with vacuum. A 9.5 can will give you 30+19 = 49, which will be very close for a Slant. I would run that for a while and see how it feels/performs/mpgs.
Users browsing this forum: Amazon [Bot] and 12 guests
