Plug wiring
https://slantsix.org/forum/viewtopic.php?t=13167
Author:  ol ron [ Sat May 28, 2005 2:27 pm ]
Post subject:  Plug wiring
Thanks for aloowing me aboard this site. I just found a really nice '71 demon to restore, and I intend to keep it Slanted. I replaced the distributor cap today, and the car won't start. It ran poorly with the old wires, one of which was burned through. I carefully replaced the wires (I thought!) and no fire. Spark is definitely there. My question: what is the position of number one plug wire in relation to the notch in the cap? I'm thinking this will solve my dilema. I'll then plug them in 1-5-3-6-2-4 clockwise.
Second question: what is the timing spec? It's an automatic tranny one barrel.
Many thanks for any help!
Ron
Author:  SlantSixDan [ Sat May 28, 2005 2:38 pm ]
#1 is the closest tower to the cap notch (slightly clockwise from the notch as you look down on the cap from above).
Set your timing to 5°BTDC for a start.
Author:  sixsignet [ Sat May 28, 2005 2:43 pm ]
Going clockwise, the #1 wire is just past the clip on the right.
Check this link out - almost halfway down there is a heading "Facts for owners".
That drawing always works for me.
http://www.allpar.com/slant6.html
Author:  ol ron [ Sat May 28, 2005 7:17 pm ]
Post subject:  Imptressed!
Just joined this site today, and I'm both impressed and very thankful. You guys are great! I got the info on the plug wiring and I was off by 110 degrees! I am so pleased that there is such a helpful and informative site for us slanted guys. My first slant was my first new car, a 1961 Valiant 170 hardtop. What a bullet proof gem. Wife Barbara cried when we sold it and got our first pickup, a 1964 Dodge 318.
I hope to be a contributor rather than a dumb questioner soon. Stay tuned for my first adventure in car restoation.
Many thanks!
Ron
:D
Author:  Pierre [ Sat May 28, 2005 9:27 pm ]
Does it really matter where #1 is located on the cap? As long as the wires are in the same direction, in the same order, and the rotor is pointing at the #1 wire when #1 is at tdc.....
Author:  SlantSixDan [ Sat May 28, 2005 9:40 pm ]
Nope, the only reason why it matters is that a set of plug wires contains wires with length based on their installation in the prescribed cap towers.
Author:  Dartvader [ Sun May 29, 2005 5:39 am ]
Just a little plug wire tip: If you use 90 degree ends on selected wires at the cap, you can keep the wires from rubbing on the fender and wearing that hole in them.
Author:  SlantSixDan [ Sun May 29, 2005 7:06 am ]
That is true. The factory did so for some years.
(That said, if you're wearing holes in the insulation, you should probably look at buying better plug wires...!)
Author:  '74 Sport [ Sun May 29, 2005 10:01 am ]
The new MOPAR cap I bought from the dealer actually has "1" molded next to the tower.
Jerry
Author:  emsvitil [ Sun May 29, 2005 11:25 am ]
Or put 1/4" wire wrap over selected areas as a sacrificial wear area....
