| New Brakes https://slantsix.org/forum/viewtopic.php?t=13212 |
| Author: | ValiantBoyWonder [ Tue May 31, 2005 3:20 pm ] |
| Post subject: | New Brakes |
so new 9" drums, shoes, hardware, rebuilt Master C. , and rubber hoses how is the pedal suppose to feel after a rebuild? mines returns slowly, like if the cylinders are pushing the pedal back out, is this right? or am i in deep doo doo..??? the car stops really good, feels nice and tight, just that the pedal returns slowly, is this a cause for worry? |
| Author: | emsvitil [ Tue May 31, 2005 3:33 pm ] |
There should be a coil return spring around the brake pushrod. My original had disintegrated, and I made a new one with piano wire |
| Author: | kesteb [ Tue May 31, 2005 4:59 pm ] |
The return spring doesn't do anything other then protect the rubber boot. I would check the adjustment of the individual brakes and then bleed the lines. A slow return of the brake pedal could also mean a bad master cylinder. A common problem with the 9" brakes. |
| Author: | SlantSixDan [ Tue May 31, 2005 5:00 pm ] |
Could also have problematic residual-pressure valve(s) in the master cylinder. What year car is this? |
| Author: | ValiantBoyWonder [ Tue May 31, 2005 6:59 pm ] |
70 valiant master cylinder was rebuilt, new springs and such and the seats were changed also, the cylinder inside looked good, no gashes or anything the brakes also started making a squeal, on the front driver side, is it because they are new???? |
| Author: | phogroian [ Fri Jun 03, 2005 7:14 am ] |
Make sure that all of the pads are adjusted so there is no too much travel before the shoes contact the drums. |
