| Tranny Swap.....HELP! https://slantsix.org/forum/viewtopic.php?t=13235 |
| Author: | Challenged71 [ Thu Jun 02, 2005 8:06 am ] |
| Post subject: | Tranny Swap.....HELP! |
I am looking to pull the 904 Torqueflite out of my 225 c.i. slant six 71 Dodge Challenger and replace it with a standard shift. Will a b/e body A833 trans bolt up to a slant six bellhousing? Reason I ask is because I got one out of a '70 'Cuda parts car. I like the slant WAY too much to get rid of it and install a v8. I just want to be able to shift my own gears! Any help is appreciated. P.S. - I also need the slant six bellhousing, flywheel, z bar, and z bar mounts to make this work! Please help! A header or crack free exhaust manifold would be nice too! Thanks, Ted tedyoung84@netzero.net 973 467 8737 |
| Author: | 65 dartman [ Thu Jun 02, 2005 12:33 pm ] |
You find a slant 6 bellhousing from an early A (64-66) which will be cast iron OR from a late A with the 4 speed overdrive (aluminum). I would guess the flywheel could be obtained from the same donor. Dollars to donuts your Z Bar and related items will need to come from a manual transmission Challenger/Cuda ($$$$). You might try Brewers or Passion POerformance for your parts. |
| Author: | mcnoople [ Fri Jun 03, 2005 6:52 am ] |
The z-bar will have to come from a slant equipped e-body. The small block bar is the wrong lenth. The bellhousing is a little harder. The 833 od trans has a larger bearing retainer (5.125 methinks) than the normal 833. I think I recall someone mentioning a shim to counter this but I don't remember the details. Of course you will need all the pedal/dash reinforcement and associated brackets used on the manual trans cars. I used to have a 72 challenger with slant and 3m trans and it was quite a challenge figuring out what parts went where since it was apart when I got it and all the parts were mixed with v8 clutch components. good luck I think I likely still have another spare z-bar that I will never use the problem is that even if I could find it I can't id it without a length. |
| Author: | Dartvader [ Sun Jun 05, 2005 12:08 am ] |
Hi Challenger. I have your bell housing. It is a slant six housing of aluminum. I used it for years behind slant, and it worked well. It has the larger bearig retainer opening for the OD 4 spd. I will sell it for $50 plus S/H. E-mail me at spowell786@aol.com |
| Author: | Bohmer2 [ Wed Jul 13, 2005 10:20 am ] |
Ok, I had been meaning to check out my 3-speed E-body to help this guy out before I saw this post. If mcnoople is still watching this post I can measure the length of my z-bar and see post the length tonight to help this guy out. There must have been some confusion when I posted earlier saying I would check my setup to help him find compatible parts because i have received three e-mails from this guy wanting to buy my 3-speed parts..which currently arent for sale. By the way mcnoople your 72 didnt get sold to a younger guy in Springfield Il did it? Just curious if I have your old car. |
| Author: | 74W100/6 [ Wed Jul 13, 2005 11:45 am ] |
| Post subject: | Headers |
Iv got a set of cliffords 3x2 long style headers for sale. I have the whole kit except for the manifold to head gasket. Drop me a line if your interested. Good luck with your tranny swap! |
| Author: | mcnoople [ Fri Jul 15, 2005 6:01 am ] |
Bohmer2 if your car is b3 petty blue it probaly is my old car. It was an odd color If you want it I still have the original am radio for it. That car is where I got most of my perf slant parts. When I got it it had a bt 833 in the trunk and offy 4bbl headers in the engine bay. |
| Author: | Bohmer2 [ Fri Jul 15, 2005 7:05 am ] |
hey MCnoople can you email me at bohmer2 at charter.net, I am 99% sure that I have your old Challenger. its b3 blue, black interior w/bucket seats, 3-speed, 83/4 rear. would like to talk to you about the car and its history. |
