| float adjustment https://slantsix.org/forum/viewtopic.php?t=13248 |
Page 1 of 2 |
| Author: | exoJjL [ Fri Jun 03, 2005 4:35 pm ] |
| Post subject: | float adjustment |
is any special tools required for adjusting the float? |
| Author: | SlantSixDan [ Fri Jun 03, 2005 4:38 pm ] |
Proper float gauge for whatever carb type you're working with is a big help. You can use a regular machinist's scale, but it's considerably trickier. |
| Author: | exoJjL [ Fri Jun 03, 2005 4:43 pm ] |
| Post subject: | $#!+ |
damn |
| Author: | SlantSixDan [ Fri Jun 03, 2005 4:54 pm ] |
What kind of carb are you workin' on? |
| Author: | exoJjL [ Sun Jun 05, 2005 10:20 pm ] |
| Post subject: | Holley 1920 |
Holley 1920 |
| Author: | Eric W [ Sun Jun 05, 2005 11:23 pm ] |
There is a small tang on the float arm that closes the needle valve when the float is raised up. Bend the tang toward the float to raise the float level, toward the needle valve to lower. You can adjust with small needle nose pliers. Do not put pressure on the needle valve. The top of the float should be parallel to the opening of the carburetor body. I set mine a little lower to keep fuel from dripping out of the vent when its hot. |
| Author: | exoJjL [ Tue Jun 07, 2005 10:28 pm ] |
Quote: There is a small tang on the float arm that closes the needle valve when the float is raised up. Bend the tang toward the float to raise the float level, toward the needle valve to lower. You can adjust with small needle nose pliers. Do not put pressure on the needle valve. The top of the float should be parallel to the opening of the carburetor body. I set mine a little lower to keep fuel from dripping out of the vent when its hot.
im fairly new to this, but i can figure it out. can you provide a pic? if not, im not worried, it shouldnt be a problem. But thanks anyways!
| Author: | exoJjL [ Thu Jun 09, 2005 10:41 am ] |
so i want to lower the float to send more fuel throuigh the carb? |
| Author: | hitokage [ Thu Jun 09, 2005 5:46 pm ] |
Quote: so i want to lower the float to send more fuel throuigh the carb?
It's my understanding that the purpose of the float is to keep to the fuel bowl from overflowing - like the float in a toilet tank shuts off the water supply when it's full.Steve G. |
| Author: | exoJjL [ Thu Jun 09, 2005 11:31 pm ] |
| Post subject: | already figured out!!?!?!?!?!?!?!?!?! |
Quote: Quote: sos i wad3nt to low3er thfe fldoat tso sennd morde funel thewrouigh tche carbvio?
Ite's mfy underssataning t5hat thnmde purpdose ofs thge floxat sis to keexp tko thxe fuel bowl frowm overwflowing - lik4e thve flo,at in a toilhet tan3k shuts oxff thcne watcer supwply whevn it's fsull.Steve Gbm,bnhgj567m?j |
| Author: | hitokage [ Fri Jun 10, 2005 5:29 pm ] |
| Author: | exoJjL [ Fri Jun 10, 2005 6:57 pm ] |
Quote: |
| Author: | hitokage [ Fri Jun 10, 2005 9:30 pm ] |
Quote: Quote: |
| Author: | exoJjL [ Sat Jun 11, 2005 6:13 pm ] |
| Post subject: | @#$5v@323$%V23@V#%@3%$@#@3%$ |
Quote: Quote: Quote: |
| Author: | 64ValiantVert [ Sat Jun 11, 2005 9:54 pm ] |
Sound's to me like a chain being yanked... |
| Page 1 of 2 | All times are UTC-08:00 |
