| 75 dart starting problems no spark,,Help https://slantsix.org/forum/viewtopic.php?t=13320 |
| Author: | junkman454 [ Thu Jun 09, 2005 8:26 pm ] |
| Post subject: | 75 dart starting problems no spark,,Help |
Just saved this one from the crusher very clean- never had a dodge before, it ran but stopped running. im not getting any spark, changed coil,cap rotor,ign. switch and ballast. i have 8vdc on the coil when cranking. is there a particular way to test ballast and install( i hooked up as it was in the car with the jumper on the non notched edge. or maybe the pepboys cap is no good, and it does have a resistor on the coil, coil wire ohms out good, any suggestion would be appreciated thanks Don Nj junkman454@hotmail.com |
| Author: | makapipi [ Fri Jun 10, 2005 12:58 am ] |
| Post subject: | no starting |
how about the ignition module , it is mounted on driver side in engine bay |
| Author: | junkman454 [ Fri Jun 10, 2005 3:34 am ] |
ignition module also changed |
| Author: | makapipi [ Fri Jun 10, 2005 12:55 pm ] |
| Post subject: | no spark |
how about the pickup coil in the distributor? when the rotor shaft spinning there should be about .1 to .4 volts ac on the 2 wires. also the resistance of that pckup coil should be around 150 to 800 ohms. that pickup coil has a connector about 6 inches from the distributor. the p up coil sends a pulse signal to the ignition module which sends the pulse to the coil , than the ign coil increases the spark voltage and sends it to the spark wires and spark plug. |
| Author: | '74 Sport [ Fri Jun 10, 2005 1:26 pm ] |
How old are the ignition wires? If the coil wire has broken down inside its sheath, it may not carry the current to your distributor. |
| Author: | Jon Dahlberg [ Fri Jun 10, 2005 2:28 pm ] |
Check the fusible links by the ballast resistor too. |
| Author: | Super6 [ Fri Jun 10, 2005 5:00 pm ] |
You should have battery voltage (or very near it) at the coil + terminal while cranking---the ballast resistor is (should be!) bypassed during cranking. Once the key is let off "start" to "run", current is routed through a second ignition wire, that runs through the ballast resistor, which should drop the voltage to ~8 volts. Electronic Ignition Wiring Diagram -S/6 |
| Author: | junkman454 [ Fri Jun 10, 2005 8:34 pm ] |
ill check all suggestions on sunday, with chucks wiring diagram and my trusty meter i hope the old girl starts., i have my fingers crossed. |
| Author: | junkman454 [ Wed Jun 15, 2005 7:06 pm ] |
i have good spark now, replaced the distributor ignition pickup, But engine floods out real fast, guess im out for a carb rebuild |
