It is currently Thu Jan 01, 2026 6:19 pm
PostPosted: Fri Jun 10, 2005 12:40 am
:shock: Ok, after new pistons, rings, rod bearings, timing chain, and a carb rebuild I buttoned it all up and fired it up.... she purrs nicely except for a slight grinding noise that seems to eminate from the vacinity of the flywheel.
It's sort of a steady white noise kind of sound with an overlapping intermitent grind. It's loud enough to hear in the cab. I don't remember that noise beibg present before the rebuild.
I pulled the lower cover off the bellhousing and took a look nothing odd in there...
I'm hoping it's not a bearing... perhaps the starter is not disengaging?
Anyone have any ideas?
64 Canadian (Dart Rear Clip) Valiant Signet Convertable 225 /6
PostPosted: Fri Jun 10, 2005 1:25 am
If it's a manual transmission, I'd say pilot bearing (is it a bearing or a bushing??????????)
PostPosted: Fri Jun 10, 2005 6:36 am
hi,a loose flywheel bolt? flywheel rubbing something? pop off inspection cover and watch & listen with engine off and running. ron
PostPosted: Fri Jun 10, 2005 9:51 am
Thanks for all the suggestions folks :)
I can't see anything odd from under the inspection cover.
It's an automatic transmission. Tha repair manual was pretty adamant that the flywheel be marked and reinstalled in the same position. I may have screwed that up somehow... I was going by some old overspray that shot into the started opening.
Is the flywheel balanced or something? Could that be it? Maybe I'll just have to try in all 5 possible positions :?
PostPosted: Mon Jun 13, 2005 8:49 pm
If it's an automatic transmission, it has no flywheel, it has a flexplate which hooks to the torque convertor. The torque convertor has enough weight that it serves the puropose of a flywheel. I don't think the slant six requires a balanced torque convertor, but the 360 does.
82 D150-225/727
02 Dakota-3.9/5 speed
Users browsing this forum: Ahrefs [Bot] and 6 guests
