| Carburettor Problem? https://slantsix.org/forum/viewtopic.php?t=13425 |
| Author: | crickhollow [ Tue Jun 21, 2005 8:43 pm ] |
| Post subject: | Carburettor Problem? |
When I start the engine I have fuel leaking from where the fuel line enters the 'carby (around the needle and seat area). I have tightened the fuel line connection, checked the needle and seat condition, however it still leaks fuel everywhere. Any help to fix this problem is welcomed. Thanks, Peter. |
| Author: | SlantSixDan [ Tue Jun 21, 2005 8:47 pm ] |
Inspect the end of your fuel line carefully; the flare may have cracked. Also check for stripped threads where the brass inlet fitting screws into the carb, and check that the proper gasket is used. |
