Edelbrock carb and timing question
https://slantsix.org/forum/viewtopic.php?t=13455
Page 1 of 1
Author:  Lancergt [ Fri Jun 24, 2005 5:06 pm ]
Post subject:  Edelbrock carb and timing question
I have a aluminum 225. Head is original stock with the surface milled -.06. I have an automatic tranny and a comp cam part# 64-240-4. I have played with my timing going from 5 to 25 degrees and it seems to run the same no matter where I set it. It runs pretty good but I want it perfect. I have an ever so slight surge at a constant speed. What should the timing be set at? I also have an Edelbrock 500 carb. Can anyone give me a good starting point on where to set the 2 mixture screws that are on the front of the carb? If you need more info please inquire.
