| Oil https://slantsix.org/forum/viewtopic.php?t=13524 |
| Author: | Slant Finland [ Thu Jun 30, 2005 12:36 pm ] |
| Post subject: | Oil |
Hello My engine project is done. What kind of oil i should use? Synthetic or mineral? 10w30 or what? Engine is from 1978 Dodge Aspen. Please help. |
| Author: | Charrlie_S [ Thu Jun 30, 2005 1:02 pm ] |
You wil get different opinions. Mine is 10w-30 mineral. |
| Author: | SlantSixDan [ Thu Jun 30, 2005 1:49 pm ] |
10w-30 mineral is an excellent recommendation for your new engine's first oil. Try for an oil rated API SL rather than API SM. |
| Author: | 440_Magnum [ Thu Jun 30, 2005 3:01 pm ] |
Quote: 10w-30 mineral is an excellent recommendation for your new engine's first oil. Try for an oil rated API SL rather than API SM.
And 10w30 synthetic is good for the long haul |
| Author: | Eric W [ Thu Jun 30, 2005 11:05 pm ] |
I like 15W-40 Shell Rotella Diesel oil. I believe it has the ratings Dan and 440 talk about. |
| Author: | dart63 [ Fri Jul 01, 2005 8:19 am ] |
15/40 seems a tad thick for the first oil in a rebuild........ I love it for my kids oil burning 2.5's though |
| Author: | Slant Finland [ Fri Jul 01, 2005 12:29 pm ] |
Thanks everyone. I think that I try that 10w - 30 mineral. I heard that if Camshaft is old, I should use mineral oil. There are lot of opinions, like Charrlie_S says. More comments? |
| Author: | SlantSixDan [ Fri Jul 01, 2005 1:31 pm ] |
There is no reason to avoid synthetic "because the camshaft is old". Breaking-in a newly rebuilt engine on synthetic is generally considered unwise unless the engine has been specifically built with this in mind (which most are not). It's really a lot more complex than it might seem. As I hinted and 440_Magnum explained, it's not necessarily the case that newer oil specs are better in every way than older oil specs. Certainly oil durability, viscosity stability, thermal stability, cold pour point, detergent-dispersant properties and resistance to sludging have all improved vastly and steadily over the last decade (let alone the last four decades!). But, some of the very newest oils are actually less suited to older engines for reasons 440_Magnum explains well. You should be just fine with any reputable brand of 10w-30 conventional oil, preferably SL rather than SM. Use good quality oil filters! |
| Author: | bondo_jonze [ Fri Jul 08, 2005 7:02 pm ] |
I like to break in on 5w30 or 10w30 dino oil (depending on how tight the bottom end is) , then switch to syn. I usually run the dino oil for the first 3000 miles with about 4 or 5 changes during that distance. I do think that the FILTER is more important then the oil on the first fire up and during priming. (heck I change the filter between prime and fireup at least once on a small block) just my $0.02 worth, though I have never had parts "escape" a sb chysler |
| Author: | Jeb [ Sat Jul 09, 2005 4:23 pm ] |
I run Quaker State 10W40 in all of my stuff, except for my Chevy which requires 20W-50. All of these additives that are good for older engines, which oils have them besides Mobil? |
| Author: | Eric W [ Sun Jul 10, 2005 12:44 am ] |
Quote: All of these additives that are good for older engines, which oils have them besides Mobil? |
| Author: | Jeb [ Sun Jul 10, 2005 1:24 pm ] |
I think I need to pick up some Rotella T at my next oil change. |
| Author: | Mguesto [ Mon Jul 11, 2005 8:01 pm ] |
Look in your local Sam's Club for the Rotella T oil. I seem to remember seeing it in 1 gallon and 5 gallon containers. I have been getting my Wolf's Head oil there and not having to worry about sending in any rebate junk and waiting 12 weeks for a check. |
| Author: | Jukka-80Aspen [ Tue Jul 12, 2005 11:04 am ] |
I have used Mobil Agri motor oil 10W30. It's diesel motor oil for tractors. My slant has now 275000 km (172000 miles) and it seems to like that oil. Doesn't costs much, about 30 euro / 20 litres and I have changed oil every 5000 kilometres (about 3000 miles). |
