| mega squirt https://slantsix.org/forum/viewtopic.php?t=13548 |
| Author: | vitamindart [ Sat Jul 02, 2005 3:40 pm ] |
| Post subject: | mega squirt |
is anyone running a mega squirt fuel injection set up on a slant??? i am thinking of trying it on my build up , just trying to figure out how i would run my nos then did'nt really want to plumb a fogger style set up was hoping to use a plate style i was thing this would make it easier to run a blower down the road if i wanted to go that route thanks for any in put or advice in adavance |
| Author: | slantzilla [ Sat Jul 02, 2005 11:18 pm ] |
Lou Madsen is running a Megasquirt. I'm sure he will chime in soon. If you run a 4bbl intake a plate system will be a piece of cake. |
| Author: | vitamindart [ Sun Jul 03, 2005 3:00 pm ] |
i was hoping to modify a aluminum 1bbl manifold and use and mustang or other readily avail throttle body to cut cost if al esle fails it will be a 4bbl manifold and a plate i just thought a fuel injected slant would be cool |
| Author: | Dart270 [ Mon Jul 04, 2005 11:04 am ] |
I have two Megasquirted Slants. One with Holley 670 cfm TBI and one with MP-EFI on a modified Offy 4bbl intake with 24lb injectors and GM TB. Ask away... Lou |
| Author: | vitamindart [ Mon Jul 04, 2005 5:18 pm ] |
would modifing a aluminum 1 bl be out of the question i'mthinking of using it and choping it up |
| Author: | Slant6Ram [ Tue Jul 05, 2005 5:52 am ] |
| Post subject: | 1 Holer |
I've got one of those stashed away in a corner for just that purpose some day. It might be a half step to learn how to get the megasquirt stuff working. I bet you could sell the intake and get back a little of your money when it came time to upgrade to the 4 bbl plate system. Another bonus is learning how to drill (or how not to drill) the bungs for the injectors on a $20 manifold instead of a $150 manifold. |
| Author: | vitamindart [ Tue Jul 05, 2005 5:22 pm ] |
yeah thats what i was thinking ,the bungs and the rails are readily availible on good ole ebay |
| Author: | Dart270 [ Thu Jul 07, 2005 7:33 am ] |
I have thought of doing the same thing on a 1bbl alum intake. I have used the Clifford 4bbl, which has inj bosses already cast in. Lou |
| Author: | Matt Cramer [ Mon Aug 01, 2005 10:48 am ] |
The only problem with modifying an aluminum 1 bbl manifold for EFI is that the hole under the carb is a bit on the small side. So you would either want to enlarge this hole, or weld it shut and put on a side mounted throttle body like Big Red's setup. Other than that, this shouldn't be any problem. |
