| Newbie here! My goals and plans... https://slantsix.org/forum/viewtopic.php?t=13621 |
Page 1 of 2 |
| Author: | BoostedSlant [ Sat Jul 09, 2005 5:08 pm ] |
| Post subject: | Newbie here! My goals and plans... |
I'm building a 73 Dart Swinger. With a boosted slant six. Here are my plans. rebuilt /6 punched .020 over port and polished head Electronic Ignition JY TBI system w/ Megasquirt setup. Custom grind Solid cam. 225*/225* @ .050" .480"/.480" lift. 340 valve springs and retainers. Solid lifters and custom pushrods. Ported exhaust manifold rebuilt /6 727 tranny out of 80's truck or van. 2500K stall 66/67 B body 8 3/4 sure grip. 3;55 or 3;23 gears. (this car will see highway use often) Spring perches relocated to fit. Cooling mist water injection kit. two stage boost control. 10 psi for cruising, and 15 psi for burnouts/racing/fun/when I feel like it...etc HY35 Holset Turbo Custom Pulse header 3" exhaust w/ Bullet style Race muffler. My question to you is, if I am always going to be shifting below 6000 RPM's, will I be alright with stock cast pistons? I want to run 8;1 compression. This car will LIVE on pump gas, and be 100% street driven. I'm wanting to net 320 RWHP so that means around 400HP at the crank. This setup should run low 12's if traction is "caught". Any other advice you could offer would be great. Saving $550 on pistons would really be a money saver, and help cutdown on the overall budget of the car. Thanks. |
| Author: | Charrlie_S [ Sat Jul 09, 2005 8:25 pm ] |
You would need to use one or the other, ported exhaust manifold, or header, not both. Maybe cast pistons would work at 10 PSI, if everthing was right on, as far as the tune up. At 15 PSI, don't think cast will hold up. Custon pushrods will not be neccessary. I suggest you use a 904 trans, not the 727. Don't know any thing about that turbo, so can't comment on that. Would also suggest PFI, instead of TBI. You will need to do some "beefing" inside the motor, to allow 400 HP. Shift point around 5,000 rpm is more reasonable. |
| Author: | VE Safari [ Sun Jul 10, 2005 12:46 am ] |
Read this good thread re turbos and cast pistons. Ray is the owner and founder of MoparMarket in Australia, and has a tuff 225 turbo. He posts here as well. MoparMarket in Australia |
| Author: | Rust collector [ Sun Jul 10, 2005 4:59 am ] |
If you have the holset, you should try it! I have a feeling it would work nicely Does it have the wastegate built into the turbo, or is it external? You may want to port the wg if it is in the turbo, as they are a bit small. I am a bit worried about the tbi thing... Can you get injectors big enough for the power, when they operate under the higher air pressure(and fuel pressure inside)? |
| Author: | BoostedSlant [ Sun Jul 10, 2005 10:51 am ] |
Ah yes, I can get big enough injectors for the TBI. I've already talked to a Tech at Megasquirt and he says that using the Megasquirt setup with the TBI should be no problem. Sorry, I meant the custom pulse header. I copied and pasted this combo that I posted on another site to hear. I want all the imput I can get and I forgot to remove the exhaust manifold part. I believe the Holset is an external wastegate turbo. On the custom pushrods, I know Chrysler wasn't exactly steller on their measurement tollerances and I've heard that with an aftermarket cam and lifters, that pushrod length needs to me measured and pushrods ordered accordingly. Michael |
| Author: | Charrlie_S [ Sun Jul 10, 2005 1:38 pm ] |
Quote: On the custom pushrods, I know Chrysler wasn't exactly steller on their measurement tollerances and I've heard that with an aftermarket cam and lifters, that pushrod length needs to me measured and pushrods ordered accordingly. Michael 1) Milling the head and/or block over about .80-.100, pushrods would be too long. Since you want About 8-1 compression, not an issue. 2) Using a "reground" cam with a very small base circle, pushrods could be too short. Not likely, with the cam specs you list. Most slant cams are on new cores. 3) Using a very very radical cam profile, with very high pressure valve springs. Pushrods might not be strong enough and bend. In this case you would want a 3/8 dia pushrod. Again, not needed, with the cam numbers you list. |
| Author: | BoostedSlant [ Sun Jul 10, 2005 4:07 pm ] |
Okay, so with a custom cam that won't go over .500" lift I don't need custom pushrods. Something that I like as it will lower the cost just that much. Thanks. Any other opinions or tips on the build? I'm thinking of just running cast pistons until they blow as I will have another shortblock that I am going to build when I have more money. Also, why the 904 and not a 727? Wouldn't it be cheaper to pickup a good 80's slant six 727 instead of build a 904? Michael |
| Author: | Rust collector [ Sun Jul 10, 2005 4:16 pm ] |
I know you can get big injectors for tbi, but how do they react to the higher pressure needed when you are under boost? Or are you doing a draw thru? If you are, the Holset don´t have the right seals... |
| Author: | Ron Parker [ Sun Jul 10, 2005 5:12 pm ] |
Why are you building a great car and not put the forged pistons in. I would recomend forged pistons git er done. Also Charlie is right the 904 is better behind a slant. Hell the one in my car is three years old and have no problems other than flex plate bolts comming loose but that just happenend at Hamilton. And all it gets is wide open every pass. Thanks Ron Parker Hell Hath No Wrath Than A Possum Scorned |
| Author: | Charrlie_S [ Sun Jul 10, 2005 5:17 pm ] |
Quote: Also, why the 904 and not a 727? Wouldn't it be cheaper to pickup a good 80's slant six 727 instead of build a 904? Michael |
| Author: | BoostedSlant [ Sun Jul 10, 2005 6:13 pm ] |
| Post subject: | $$$ |
Going w/ forged pistons all depends on how much $$$ is available at the time. Okay, so the a904 it is. What all would you suggest for the tranny being freshened up? Thanks. Michael |
| Author: | Ron Parker [ Sun Jul 10, 2005 6:28 pm ] |
I am lucky because i have a transmision builder that goes back and knows MOPAR trans. My trans is a racing trans and he built it for that doint know the details I told him what i wanted and he built it. But it gets real hard racing action ask Charlie and he will tell you the second person you want to know is the transmision builder . The first for me is the engine builder. Thanks Ron Parker Hell Hath No Wrath Than A Possum Scorned |
| Author: | BoostedSlant [ Mon Jul 11, 2005 2:19 pm ] |
| Post subject: | Kickdown linkage on TBI setup? |
Okay, since the stock kickdown linkage is "carb specific" What is to be done when I go to the TBI MS system? Thanks. Michael |
| Author: | Charrlie_S [ Mon Jul 11, 2005 4:43 pm ] |
Use a cable kick down. Either a Lokar, or homemade from a motorcycle/bicycle cable. |
| Author: | BoostedSlant [ Mon Jul 11, 2005 5:04 pm ] |
How exactly does a cable kickdown work? Thanks. Michael |
| Page 1 of 2 | All times are UTC-07:00 |
