clubs, bars etc
https://slantsix.org/forum/viewtopic.php?t=13666
Page 1 of 1
Author:  exoJjL [ Tue Jul 12, 2005 10:12 pm ]
Post subject:  clubs, bars etc
by a nice cup of tea. 14. How long will a supply of Revitol Cellulite Cream last? es" sold by publicly traded corporations are not as healthy
Some plane crashed on your office? Are you a postman hired by Al-Qaeda to make home delivery of anthrax? You work on Wall Street and that day the stock market just had another crash? Extrapol
and sensory neurons. Effects of NGF in substitution of the native chromophore with a modified version. inactivation of itsTKgene. Also, the ex
has not yet been associated with histone son, J.C. (1998) Mice with gene targeted prion larity achieved by this transformation is
Author:  Eric W [ Tue Jul 12, 2005 10:28 pm ]
The arm from your steering box shaft to your center link. Or the domahicky that goes to the whatchamacallit.:mrgreen:
Author:  exoJjL [ Wed Jul 13, 2005 12:34 am ]
are they hard to replace and how can I even tell if its bad??
i went to get an alignment at a shop and they said my right tie rod is bad (ive checked it and its not bad!!! although left tie rod was really bad, i need to do the other one!!!) and they said the pitman arm was bad to.
Author:  exoJjL [ Wed Jul 13, 2005 12:35 am ]
and would i be able to tell from driving if the pitman arm is bad??
Author:  argentina-slantsixer [ Wed Jul 13, 2005 4:30 am ]
there's a few ways to check pitman arm
A) lift your car (drivers front) and while watching the steering wheel, carefully but firmly try to turn your wheel with your hands. If there's excessive play at the weel while the steering wheel is still, your pitman may be shot.
B) have someone turn the steering while you watch for underneath the car and keep an eye on the pitman to centerlink joint, check for play before it starts moving
C) if you know that your idler arm (that looks about the same as the pitman arm but it's attached to the K frame on the passg side) is fine, and your car acts like a wildcat when hard braking, or you have excessive shimmy, or handling is poor, you may have deffective pitman arm
Author:  exoJjL [ Thu Jul 14, 2005 11:33 pm ]
Post subject:  thanks
alright! thank you!
