| clutch pack Bench test https://slantsix.org/forum/viewtopic.php?t=13719 |
| Author: | relic-lover [ Sun Jul 17, 2005 3:31 pm ] |
| Post subject: | clutch pack Bench test |
I decided to dig into my own 904 instead of hiring it out to a shop. It was not as hard as I guessed, I got it torn down and back together with only this one question. The transmission was assembled including the Torque Converter and then the pan and valve body were removed for the air pressure tests described in the FSM. This is a 65 A904-G TorqueFlite 6. During the air pressure bench test when air was put into the "front clutch apply" port - the clutch applied with a thud as described - there was also air coming out the "rear clutch apply" port. Is it normal to have the rear and front clutch apply ports cross pressurize each other? Or did I miss something when reassembling it? |
| Author: | Guest [ Mon Jul 18, 2005 8:32 pm ] |
| Post subject: | Could both be broken the same way ? |
The 63 904 has the same issue - the air put into the rear clutch apply port leaks to the front clutch apply port. I traced the passages through the front pump to the reaction shaft. The front clutch port comes out on the reaction shaft between two seal rings and the rear clutch passage comes out on the bore inside the reaction shaft. My guess is the air leaks past the seal ring toward the rear of the reaction shaft, then around the end and into the inside bore in the reaction shaft. I am going to surmise this is a normal behavior based on the premise it is unlikely both transmissions would be broken in that same manner. Is posting replies to your own questions as bad as talking to yourself? |
| Author: | relic-lover [ Mon Jul 18, 2005 8:34 pm ] |
| Post subject: | That was my post. |
Why do I get logged out while I post ? |
| Author: | bossanova6 [ Sun Jul 31, 2005 4:51 am ] |
I'm about to tear down my 65 A-904 would any one happen to have a copy of the factory service manual? |
