| UCA bushings https://slantsix.org/forum/viewtopic.php?t=13720 |
| Author: | sixty4dartgt [ Sun Jul 17, 2005 4:13 pm ] |
| Post subject: | UCA bushings |
How do I torque the UCA bushings with the tire on ? I was told to toque the UCA bushings AFTER I set the ride height and while the car was on the groud. This prevents the bushings from being "clocked". There is no room to get a torque wrench in there, however. All that I can think of is to put the car on a jack stand and then jack up the LCA so that it is in the same postion as when the car is on the ground. Thanks |
| Author: | Dart270 [ Sun Jul 17, 2005 8:31 pm ] |
Jack on the LCA with the wheel off works. You can also use a reg wrench to partially torque them with the car on the ground, then jack up and torque. I never use a torque wrench, FWIW, just crank em. Lou |
| Author: | sixty4dartgt [ Sun Jul 17, 2005 10:39 pm ] |
Thank you, sir. |
