It is currently Wed May 06, 2026 7:42 am
PostPosted: Mon Jul 18, 2005 7:45 pm
I managed to pull the center link on the 1965 Barracuda. The idler is good, but the pitman arm is bad. Is there a source out there for a new one? I saw that PST has them for $100. That seems a bit high. Rock doesn't have them. So, is there some secret code for them?
[Edit] I would love to update to a newer steering box as well. Can I get a newer steering box, and a later pitman arm that fits, and keep the geometry right? Did they change the length or other dimensions of the pitman arm when they changed the sector size?
Thanks,
PostPosted: Mon Jul 18, 2005 9:05 pm
schucks has a pitman arm for $36. Im not sure if I want to get that one though......
PostPosted: Mon Jul 18, 2005 9:09 pm
Steering box interchange is '62-'72 A- and B-body, all engines.
Pitman arm interchange is '62-'66 A-body, all engines.
They are expensive...!
 Post subject: Pitman arm
PostPosted: Mon Jul 18, 2005 9:31 pm
Rare Parts in Stockton CA has parts for your Barracuda. They are a manufacturer and discourage small quantity orders with high prices. AutoZone can order the parts from Rare Parts for less than if you buy direct. The Rare Parts pitman arm was around $80 on the autozone web site.
 Post subject: Re: Pitman arm
PostPosted: Mon Jul 18, 2005 10:02 pm
Sorta. They're mostly a "buy-up-old-stock-cheap-and-sell-it-expensive" outfit. Also a "Send-out-yard-rats, collect-old-ones, drill-out-and-claim-to-rebuild" house.
 Post subject: Autozone? Yes.
PostPosted: Tue Jul 19, 2005 7:19 am
Thanks for the tip on autozone. I went with them.
Everybody else ( espo, just suspension, etc) was selling the exact same brand for $130 and up.
It turns out Moog never made these, although TRW might have. So, for the most part, once Chrysler quit making the parts, that was it.
 Post subject: Re: Autozone? Yes.
PostPosted: Tue Jul 19, 2005 7:25 am
Huh? Yeah, they did. All the major steering-and-suspension companies at one time made this part. Moog, TRW, Perfect Circle, etc.
PostPosted: Tue Jul 19, 2005 7:32 am
The parts guys said that there was no number, hence, no production.
I would love to be wrong on this. We need all the parts for the older a-bodies that we can get.
PostPosted: Tue Jul 19, 2005 7:38 am
MOOG does not currently make them (or sell under their name).
PostPosted: Tue Jul 19, 2005 7:41 am
Well, yeah, not now, there isn't. The newest car that uses this item is about to turn 4 model-decades old.
But when this was a fast-moving part because there were lots of '62-'66 A-bodies on the roads, all the major companies (and some minor ones) made it.
