| Drip edge material https://slantsix.org/forum/viewtopic.php?t=13890 |
| Author: | bbbbbb9 [ Mon Aug 01, 2005 9:18 am ] |
| Post subject: | Drip edge material |
Is the material in the drip edge on a 64 Dart simply bondo? |
| Author: | SlantSixDan [ Mon Aug 01, 2005 9:51 am ] |
Please be more specific about what you mean when you say "drip edge". This could refer to a lot of different areas on the car. And no, there was no Bondo (nor anything even similar to Bondo) applied to the car by the factory. |
| Author: | GuyLR [ Mon Aug 01, 2005 9:56 am ] |
There was a semi-hard sealer in the bottom of the drip flange. Probably a rubber based material. If you are replacing it then a modern silicone based sealant that will take paint would probalby work well. |
| Author: | bbbbbb9 [ Mon Aug 01, 2005 9:57 am ] |
Quote: Please be more specific about what you mean when you say "drip edge". This could refer to a lot of different areas on the car.
Sorry, had the car for 10 years and the only thing I've ever referred to as a drip edge, is on the roof above the doors. Is there another?
| Author: | bbbbbb9 [ Mon Aug 01, 2005 9:59 am ] |
Quote: There was a semi-hard sealer in the bottom of the drip flange. Probably a rubber based material. If you are replacing it then a modern silicone based sealant that will take paint would probalby work well.
Original Tucson car and this material is peeling up in chuncks.Soon (I hope), I will be painting it and of course this is prep. Thanks |
| Author: | '74 Sport [ Mon Aug 01, 2005 10:02 am ] |
As said above, just use a good paintable seam sealer. I bought a tube of 3M sealer from my automotive paint supplier. Jerry |
| Author: | steponmebbbboom [ Mon Aug 01, 2005 3:25 pm ] |
3M makes a brushable seam sealer in a quart can that has the exact same firmness when cured, the only trick is getting it to lay in the channel flat like the original sealant did. Jerry's got it right; seam sealer is what you want to shop for. I havent seen this sealer in a tube but then again, I havent kept up on paint and body supplies in the last few years. |
| Author: | 69a100 [ Tue Aug 02, 2005 2:22 pm ] |
| Post subject: | Sealer |
This topic came up over on moparts.com, heres a link to it. http://board.moparts.org/ubbthreads/sho ... ost1853471 |
