| folks, what rear end is this? https://slantsix.org/forum/viewtopic.php?t=13898 |
| Author: | rock [ Mon Aug 01, 2005 6:30 pm ] |
| Post subject: | folks, what rear end is this? |
Folks, I can't find this in old posts. I count 10 bolts around the differential housing as I lay under my truck bed ('64 d100 1/2 ton shortbed with 3 speed) Is this the 8 3/4? I have found some surprisingly beefy parts in this truck merely, I guess, because it was a truck. Or is this the 7 something rear end? Thanks in advance, rock |
| Author: | Jeb [ Mon Aug 01, 2005 7:41 pm ] |
If the back cover has no bolts on it and is one piece, it is an 8 3/4. If it has a rear cover that is held on by 10 bolts, it is an 8 1/4. The only pickups that the 7 1/4 made it under were the 4-cylinder Dakotas. |
| Author: | SlantSixDan [ Mon Aug 01, 2005 8:51 pm ] |
Quote: If the back cover has no bolts on it and is one piece, it is an 8 3/4.
Not necessarily applicable to the OP's '64 truck. Remember, the 8-1/4" rear axle commonly identified by a 10-bolt cover wasn't introduced until 1969. There were lots of different rear axles prior to '66, many of which have 10-bolt covers. Best source of answer to this question is the FSM.
If it has a rear cover that is held on by 10 bolts, it is an 8 1/4. |
| Author: | rock [ Tue Aug 02, 2005 5:15 pm ] |
| Post subject: | Thanks guys, I found a casting number to chase |
Thanks much to both y'all! Heartened by both, and finally getting smart enough to do some web work after Jeb's reply, I crawled back under with the mosquitoes and found a casting number on the part of the body holding the pinion gear "stem"..the rear end has a welded cover facing the real back of the truck and 10 bolts "inside" facing the cab. The casting number is 2070741 with a smaller 23 cast underneath that next to the old time (pre-pentastar) logo . AIn't vehicle work fun! Dennis rock |
| Author: | SlantSixDan [ Tue Aug 02, 2005 7:03 pm ] |
That there is an 8-3/4" rear axle. Congratulations. |
| Author: | 65 dartman [ Tue Aug 02, 2005 7:07 pm ] |
And you probably have the brake drums secured by a rather large nut - oh joy!!! Start looking for a suitable brake drum puller! |
| Author: | exoJjL [ Thu Aug 04, 2005 10:37 pm ] |
ok so a rearend with 8 bolts on the back is what???? |
| Author: | SlantSixDan [ Fri Aug 05, 2005 10:46 am ] |
Quote: ok so a rearend with 8 bolts on the back is what????
A 7-1/4" with one cover bolt missing...?
| Author: | exoJjL [ Fri Aug 05, 2005 5:12 pm ] |
???????????????????????????????????????????????????? what years were the 7 1/4 used?????????????????????? |
| Author: | SlantSixDan [ Fri Aug 05, 2005 5:52 pm ] |
Quote: ????????????????????????????????????????????????????
'60 (Valiant) to '98 (Dakota).
what years were the 7 1/4 used? |
