| adapter https://slantsix.org/forum/viewtopic.php?t=13926 |
| Author: | Dustenn89 [ Wed Aug 03, 2005 4:44 pm ] |
| Post subject: | adapter |
is there an adapter for a 2bbl to go on a 1 bbl manifold |
| Author: | Dustenn89 [ Wed Aug 03, 2005 4:56 pm ] |
also what is the best 2bbl i can get that will hook up easily with no mods if possible |
| Author: | argentina-slantsixer [ Wed Aug 03, 2005 5:56 pm ] |
| Post subject: | Re: adapter |
Quote: is there an adapter for a 2bbl to go on a 1 bbl manifold
I tell you what: get a funnel and try to pee thru the small end.... that's what's gonna happen if you are lazy enough to swap manifolds get a 2 bbl manifold, carter BBD and all the linkage from a 80's aspen, or a truck. They gonna work great and it's almost a bolt on deal (only that you're bolting on using rusty bolts |
| Author: | Pierre [ Wed Aug 03, 2005 6:45 pm ] |
Clifford sells them, I believe summit does too. Could of sworn I saw one at kragen too. Be careful about hood clearance |
| Author: | SlantSixDan [ Wed Aug 03, 2005 7:55 pm ] |
argentina-slantsixer is right: 2bbl-carb-onto-1bbl-manifold adaptors are pointless and dumb. Just get a 2bbl intake manifold! |
| Author: | sandy in BC [ Wed Aug 03, 2005 8:14 pm ] |
OK...so I tried peeing into the funnel...but my car still isnt fast..and my fingers are wet....should I try a beer bottle? or,,,.should I use a Chev funnel? |
| Author: | mrhite65 [ Wed Aug 03, 2005 9:33 pm ] |
Here is 2 sites http://www.stoveboltengineco.com/acartp ... catcode=33 and http://store.wpsracing.com/cpprcaad.html. I used the stovebolt adapter to put on my Holley/Weber 5210 2bbl. My site has some pics. http://www.cardomain.com/ride/658846 |
| Author: | argentina-slantsixer [ Wed Aug 03, 2005 10:07 pm ] |
Quote: OK...so I tried peeing into the funnel...but my car still isnt fast..and my fingers are wet....should I try a beer bottle? or,,,.should I use a Chev funnel?
Oh, my... if you tried to pee into the small end of the funnel and your fingers ended up wet you may have forgotten to release the parking-son brake... |
