| Custom axles or re-spline? https://slantsix.org/forum/viewtopic.php?t=14070 |
| Author: | 64 Convert [ Wed Aug 17, 2005 6:13 pm ] |
| Post subject: | Custom axles or re-spline? |
I'm beginning to collect parts for an A-body 8-3/4 and would like opinions on axles. I have the housing, but need to pick up everything else. Since I need to do something with axles to get the big bolt pattern, I'm debating which way to go. I could buy a complete C-body rear end to get the misc parts I need and then have the axles re-splined, or I can order new, custom A-body axles from one of the national companies. If I buy new, should I get them with green bearings? I've heard good and bad, but since I don't abuse my Valiant, I suspect they would work just fine. If I re-spline, has anyone had them done for less than the $150 I was quoted? |
| Author: | GuyLR [ Thu Aug 18, 2005 6:03 am ] |
I hod a pair of C-body axles cut down and resplined by Moser for about that price several years ago for my '65 Barracuda. One thing to be aware of is that the C axles have a thicker hub flange on them and it pushes the wheels way out. With a narrow A-body like yours if you go to say a 7" wide wheel you will need at least 4.5" of backspacing minimum to make the tire fit and not rub the fenders. It would be less of a problem with a Wagon and the full circle wheel cutouts but yours are tight. |
| Author: | slantzilla [ Sat Aug 20, 2005 10:50 pm ] |
I had Moser cut and spline a set of E-body axles. It was about 4 years ago and at that time it was $85. They also installed green bearings and put in long studs for another $90. If you use C or E body axles you will also have to have B.C, or E body brakes. The end of the axle is longer and A body brakes will not work. You can also have your A body axles and drums redrilled to 4.5. |
| Author: | 64 Convert [ Sun Aug 21, 2005 4:58 am ] |
Quote: I had Moser cut and spline a set of E-body axles. It was about 4 years ago and at that time it was $85. They also installed green bearings and put in long studs for another $90.
I don't have any of the brake parts yet, or the original SBP axles, so the redrilling option is not there.If you use C or E body axles you will also have to have B.C, or E body brakes. The end of the axle is longer and A body brakes will not work. You can also have your A body axles and drums redrilled to 4.5. Am I correct to assume that new Yukon axles for an A-body are the same as the originals, except with the LBP? Would I need to find drums that are unique to A-bodies and have them redrilled? I guess I need to check out the brake situation before ordering anything. I thought they would be interchangable on all 8-3/4 setups. |
| Author: | Charrlie_S [ Sun Aug 21, 2005 5:04 am ] |
Quote: You can also have your A body axles and drums redrilled to 4.5. |
