| new plan /6 build https://slantsix.org/forum/viewtopic.php?t=14133 |
| Author: | Guest [ Mon Aug 22, 2005 2:47 pm ] |
| Post subject: | new plan /6 build |
ok after some thinking maybe high compresion isn't the way to go for my build . i think mega squirt fuel injection , and a turbo i think this way it will be more streetable still give me the power i want/need and it will look cool now heres where i need some help how do i figure out what size throttle body i need , i'm planning on modifying a alum 1bl intake to look somewhat like the newer import intakes (will this work or is it a headache waiting to happen) what size turbo do i need and wheres the best place to get one, what is the max compression i should run , do i need a specail cam?for a turbo application??also where can i get a header flange so i can make my own turbo manifold i also just want to add you guys rock all the info and help has been great |
| Author: | vitamindart [ Mon Aug 22, 2005 2:49 pm ] |
doh i forgot to login , i hate when i do that |
