| a833 clutch linkage https://slantsix.org/forum/viewtopic.php?t=14137 |
| Author: | 85Ramtruck [ Mon Aug 22, 2005 8:21 pm ] |
| Post subject: | a833 clutch linkage |
Hey, I have a 85 dodge d100 with a built 360, it was a slant six truck......and I bought it done but the clutch fork was a bit to short, so I took it apart. I has the clip type fork, not the ball type.......so I order the correct fork for it and then I noticed there is no hole in the bellhousing for a ball type fork......so what year is this bellhousing? do they make the clip type fork that's about 2 inches longer? could I have the wrong z bar? all these parts were ordered from napa Rober |
| Author: | james longhurst [ Wed Aug 24, 2005 8:22 pm ] |
i have no idea what year your bellhousing is. there should be a date code stamped in the casting, but i think you need to pull the bellhousing out to see it. i am pretty sure the v-8 fork is a bit longer than the /6 (or vice-versa.) i think one is 10 and the other is 12 inches. i recently read some posts on moparts about this when i was piecing together the clutch linkage for my car. i think mopar performance also offers new v-8 forks with a new pivot (clip-type.) hope this helps. -james |
