It is currently Tue Nov 24, 2026 5:55 pm
PostPosted: Mon Sep 05, 2005 9:43 am
Car Model: 69 Dart Slant 6
My 69 Dart had the idiot light system. I'd like to install a real aftermkt.
guage. Is there any that use the stock sender, or does that have to be changed? :wink: Is it down by the oil filter? The reason I'd love to use the sender that's there now is that there is already a place in the wire I could hook into and it would be a real easy deal.
PostPosted: Mon Sep 05, 2005 10:49 am
The "sender" for the idiot light is a pressure switch - it's on or off, depending on the oil pressure. On my '64, the switch is on the passenger side of the block, near the transmission bellhousing.
To use a gauge, you'll need to either plumb a pressure line to a mechanical gauge, or add a sensor designed for the electric gauge.
To keep the idiot light and a gauge, use a tee fitting. The pressure switch goes in one side, and the sender in the other.
PostPosted: Mon Sep 05, 2005 10:56 am
yep. Easiest to change to a commonly available 1/8" NPT sender for your "idiot light" while you're at it, too. That will simplify the adaption of the tee. Also, cut the end off of one of the plastic insulation "nails" protruding through the firewall near where you want to mount the gauge (it is hollow inside). Use this as a grommet to run the line through, you won't even have to drill a hole! Make sure you get the copper capillary line, and throw the plastic one that comes with the gauge in the trash.
D/W
If it ain't broke, fix it!
PostPosted: Mon Sep 05, 2005 10:59 am
How the hell do you spell "gauge" by the way? :lol: I never get that one right!
D/W
PostPosted: Mon Sep 05, 2005 11:56 am
You spelled it correctly that time! I have to think about it every single time, too.
Agreed on the copper line. Make sure you put a loose loop in the line, to allow for some movement. Hot oil is no fun outside the engine.
:shock:
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 2 guests
