| Manual Brake Pushrod- Early A and A lengths https://slantsix.org/forum/viewtopic.php?t=14267 |
| Author: | imnoisydart [ Sun Sep 04, 2005 3:03 pm ] |
| Post subject: | Manual Brake Pushrod- Early A and A lengths |
Anybody know if the 63-66A and 67-72 A body manual master cyl. pushrods are the same length - if not , which is longer or shorter? |
| Author: | SlantSixDan [ Sun Sep 04, 2005 3:16 pm ] |
Pretty sure the '67-'72 pushrods are longer, but also almost certain there are multiple different '67-'72 pushrod lengths, depending on brake system (9" drum, 10" drum, disc) and year. |
| Author: | relic-lover [ Sun Sep 04, 2005 4:02 pm ] |
| Post subject: | MC Pushrod length |
Should we try to collect data and see if we can determine how many pushrod lengths there are out there? I have an aftermarket single pot MC for 4 wheel 9" drums on a 1961 Valiant - I also believe this same aftermarket MC to have application on a 1963 dodge dart - again 4 wheel 9" drums manual brakes. The pushrod length is 6 1/2" in overall length. Or 5 3/4" from the tip to the leading edge of the pedal bolt hole. |
| Author: | 73ScampSSS [ Fri Sep 09, 2005 9:04 pm ] |
I got the adjustable brake pushrod from Mopar, and the thing is too long to fit on my 73 Scamp with manual brakes. I had to cut threads farther down then cut 3/4" off the end to make it shorter. Then the pushrod hole for the brake pedal bolt was too small so it was either drill it larger, or get a different bolt, so I got a 7/16 bolt to fit the pedal hole, then got a nylon spacer to take out the play in the setup. Small hassle but it works now! |
